Results 1 to 7 of 7
Thread: bigger calipers
    1992 VP commodore
    Aug 2010
    warner, queensland
    Default bigger calipers
    im after any ideas on how to get some bigger calipers for my VP
    i have a set of slotted rotors for the front, but they are bigger then the stock units im currently running
    the rotors that i want to put on are roughly 290mm
    ive heard i can use the calipers from a VR/S, is this correct?
    are there any others i can use?
    and can i keep the existing M/C or do i need to upgrade that also?
    thank you
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    vp are 290mm discs with finned calipers vn are 270mm and non-finned calipers pretty sure vr and vs calipers are the same part as vp
    Dec 2009
    Quote Originally Posted by delcowizzid View Post
    I think some VP's (Series 1) came out with the smaller calipers and rotors as they still had 14" wheels.
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by wortus View Post
    Correct, also not all VN's are the smaller rotor. All FE2 optioned or V8 models had the larger setup.
    Selling FG G6E Turbo and buying a N/A Supra
    VN Executive
    Apr 2007
    Wellington, New Zealand
    some GTS models also have the larger calipers, you can tell by the FIN's on the top or side.
    If you are keen on spending some serious money like $2500NZD, PBR make a kit just for the VN\VP.
    It consists of:
    FRONT
    330mm Slotted and Cross Drilled rotors
    Twin Pot Calipers
    Braided Hoses
    REAR
    270mm (i think) cross drilled and slotted rotors
    Single pot caliper
    braided hoses.
    Ill try find you the link.
    They are OEM parts so they will just bolt on the same was the VN's do. They have the same stupid hub design so you dont need to use dodgy hub adapters.
    VN Executive
    Apr 2007
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by Anthraxnz View Post
    It consists of:
    FRONT
    Twin Pot Calipers
    Braided Hoses
    REAR
    Single pot caliper
    braided hoses.
    GTS is just some made up NZ bullshit. It's a S with some stupid badges.
  1. vt bigger camber kit?
    By lildavo in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-07-2010, 07:13 PM
  2. [VIC] VT front calipers + discs/ vn-s rear calipers painted in 2pak red
    By wildss in forum Parts And Other Items For Sale
    Last Post: 21-05-2010, 09:30 PM
  3. [NSW] SWAP: My VZ Calipers for near new VS Calipers-fronts-Sydney
    By 2Com in forum Parts And Other Items For Sale
    Last Post: 09-05-2009, 01:27 PM
  4. *i Bigger Better*
    By redcv6 in forum Car Audio
    Last Post: 10-01-2007, 04:46 PM
  5. Want Bigger Rims 20" or Bigger Legally
    By gooley in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2007, 03:15 PM
