Results 1 to 25 of 25
Thread: Front tyre wear issues
    S/C VN, VY SS, Waverunner GP1200
    Dec 2005
    S.A
    Default Front tyre wear issues
    My bog standard VN seems to chew the outside of the front tyres, mainly the left side as pictured. I put new caster rod bushes in about a year ago and had a wheel alignment done recently.
    Any ideas what could cause this?
    Attached Thumbnails Attached Thumbnails Front tyre wear issues-front-tyre-wear.jpg
    calis vn v8
    Jan 2008
    has your car been lowered ???
    i had a few tyre issue's - one problem believe it or not was the top trailing arms on the diff were totally worn out causing handling and front tyre wear problems.
    tower struts getting worn.
    I do understand that vn holden wheel alignment settings that are in their computers are questionable ???
    unless racing i got my fronts set to .5 negative on camber i think computer settings are 1.5 - 2.0 tolerance......
    thinking these wheel alignment guys are the biggest rip off today - they dont even road test any more and dont check for rubbers worn - just set toe in and out and charge you......
    question them about it and get answers - if they cannot answer you - go somewhere !!
    calis vn v8
    Jan 2008
    go some where else - suppose to say
    also - once a tyre starts wearing from a year ago and you get a wheel alignment done because you notice it - apparently the tyre will continue to wear in that way.
    Jesterarts's Avatar
    Jesterarts is offline Your freedom ends where mine begins
    2005 HSV Z R8 Manual
    Nov 2005
    Mornington, VIC
    Too much toe-in from the alignment?
    Any knocking from the front end turning from lock to lock and over bumps?
    Is the car really over-steery?
    92 VP Series 2
    Jan 2009
    East Brisbane
    probably best to go to somewhere like pedders or fulcrum or something for a cheap suspension check. they'll give you an idea to whats wrong, however dont just believe everything they say, they are known to screw people around and add shit that isnt actually wrong with your car (myself included). does the car handle strangely at all? or does it seem to handle ok but just the tyres wear strange?
    BURNOUT BAZZA's Avatar
    BURNOUT BAZZA is offline BOB DA FITTER
    92 VP calais, 81 VC Commodore
    Apr 2009
    Skye, Vic
    Looks like ur running to much positive camber. i think u should take the car to another place for a wheel alignment. guys down at my local pedders are quite good. well good to me anyway. just go in and ask for an alignment and then they should tell ya afterwards what they found.
    nathanVY's Avatar
    nathanVY is offline need boost...
    03 VY Calais, 99 VT Equipe
    Dec 2009
    Geelong, VIC
    My VS is doing the exact same thing. and I do have clunking going on, sometimes over bumps and almost always when turning certain directs in about 60% lock.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by nathanVS View Post
    Could be the top bearing not working as it should - it winds up the spring in the front and goes clunk when truning.
    and 3 Dangerous non ABS VN's
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by Shearer View Post
    My 88 wagon has done this from new on all sizes of tyres. The car steers OK and handles no problems. But the left front edge is gone after 30,000 kms if not rotated. Funny how the right side is never a problem on the out side edge.
    Dec 2005
    S.A
    Quote Originally Posted by ybl8te View Post
    Car has the standard VN springs.
    These are the specs after the wheel alignment:
    Camber for L & R: -1.0 degree
    Caster for L: 2.0 R: 2.2
    Front Toe-In (mm): 1mm both sides
    There are minor knocking from the front end too (especially the left side), noticeable on rougher surfaces -prob the struts are knackered.
    nathanVY's Avatar
    Dec 2009
    Geelong, VIC
    Quote Originally Posted by 88GreenVN View Post
    Quite possibly, can you explain a bit more? Steering also pulls all over the place and is a lot worse when braking.
    Car has been on superlows in the front for a few months now so that may be taking it's toll. Rims are 17x8.
    88GreenVN's Avatar
    Jun 2006
    When I got the white VN Calais it had been crashed and the pan hard rod mount had been ripped out of the chasis. I fixed that up and still had a clunk in the front. Mechanic said the spring had rotated in the strut and he twisted it around into place. All good for 30 seconds until I turned out onto the road. Clunk again. All the suspension was checked over - new link pins and the top bearing plates were replaced. WOW what a difference that made, tight steering and clunk were gone and the steering was light again (calais var ratio). So the bit that you see when under the bonnet (strut top) may well be binding up on the pring.
    Jack the front up so you can turn from lock to lock and watch to see if the spring is moving in the strut.
    88GreenVN's Avatar
    Jun 2006
    The shocks being knackered wont be the issue tho. I think the wear on the outside left is a VN thing. We tried several settings on the wheel alignment with no fix (we had access to the Stores and Transport workshops to play)
    Dec 2005
    S.A
    The most interesting thing, my other VN which is lowered considerably, has more kays on the clock, 17x8in rims and adjustable strut tops has no front tyre wear issues at all.
    Maybe benefits from adjustable strut tops?
  15. #15
    Apr 2009
    Skye, Vic
    hey when u put the superlow springs in. did u get a wheel alignment? because it sounds like ur toe is way out if its scrubbing the tires and steering all over the place.
    or maybe a rack end is rooted. i had that on my VC commodore was veering all over the shop at 100k's
    the other thing that accures when u have ur car to low is Bump steer. thats something that could be happening.
  16. #16
    tr3nt's Avatar
    tr3nt is offline trent was 'ere
    VP Calais International 5L
    Sep 2003
    Melbourne, AU
    Quote Originally Posted by BURNOUT BAZZA View Post
    Tucketts Tyrepower FTW!
    Quote Originally Posted by hakhawk View Post
    if you pay for fuel, ill drive up and drive you around in the bmw. assuming your(hopefully hot) date rides shotgun, and you get the boot, dont worry, its well ventilated if ur dates not so, you can share the boot
  17. #17
    Apr 2009
    Skye, Vic
    nah i got to pedders in frankston now. get my wheel alignments for $20 they like me down there
  18. #18
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Check ya wheel bearings.
    Looks like you have a bit of play in one.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
  19. #19
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    I reckon it's the strut top plate. It probably hasn't been aligned with the right holes (the ones in the actual strut tower). There are three bolt holes, hence 3 different combinations. One will give you neg camber, one will give positive and the other should be right.
    Just look at the strut top.... The shock bolt doesn't come through dead center does it?
    ...Just something to consider. Had this issue with two VN's i've owned in the past
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
  20. #20
    1999 S2 VT
    Oct 2010
    I know about Toe in/out from racing RC cars but have never heard about toe on Real 'everyday' cars and don't quite understand why it would be used on them.
    To me it sounds like a great way to increase wear on your tyres for no good reason whereas in a racing situaltion i can see the advantages for using it.
    Anyone care to enlighten me as to why its done ? lol
    Ask question and your an idiot for 5 min'. Don't ask and your an idiot for life...
  21. #21
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by RUF 231 View Post
    Very good point - when I moved it around to counter the outside left wear - the wheel alignment was way out - so we moved it back.
    Sounds like a clear case for adjustable strut tops to me.
  22. #22
    Dec 2005
    S.A
    Quote Originally Posted by Andrew426 View Post
    I checked the wheel bearings today and they are nice and neat.
    I think I know the type of strut top you mean, It does have three 'positions'. Currently the shock bolt is positioned towards to firewall. Last year I had a wheel alignment at another place and they rotated the struts towards the front of car to 'correct the camber'. It was terrible to drive, it would change direction on the road over uneven surfaces. Quite dangerous to drive as it steer into oncoming traffic.... I rotated them back to the normal position.
    Adjustable strut tops are on the cards now.
    Ahhhhh.... wheel alignment is the VN's Achilles Heels
  23. #23
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    yeah full caster is the only setting for vb-vp unless you get your towers slotted or fit adjustable strut tops most wheel alignment places will just set the tops at full caster and do toe in setting.one thing to watch out for is dont fit a left strut top on the right and vice versa it makes your front left camber outwards when at full caster setting
  24. #24
    1990 VN Executive
    Nov 2005
    They do a good alignment too.........When I get new tyres fitted at bob jane or wherever and they recommend a wheel alignment I say know and book it in a t Franga Pedders
    VN BT1 Mock Up Commodore
    Dynamic Locksmiths
  25. #25
    Apr 2009
    Skye, Vic
    yep guy at the counter is awesome to. went in there the other day and ended up chatting to him about cars for almost 2 hrs lol Top bloke
  1. VE SV6 Tyre Wear
    By Jethrotracey in forum VE Holden Commodore (2006 - ?)
    Last Post: 04-02-2012, 12:26 PM
  2. front driver-side tyre wear
    By D-Man in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 31-07-2009, 01:31 PM
  3. tyre wear
    By younglion in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-09-2007, 10:10 PM
  4. tyre wear
    By HOTPLATE in forum General Discussion
    Last Post: 11-10-2005, 01:18 AM
  5. VY Tyre wear
    By keithVYSS in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-09-2004, 06:33 PM
