Results 1 to 7 of 7
Thread: Auto won't shift into 3rd
    VT Series 1 Berlina Wagon
    May 2010
    Croydon, Vic
    Default Auto won't shift into 3rd
    Was driving fine last night then 5pm from home taking off from lights I got to about 55 to 60 and the car went to shift into 3rd but felt like it went to neutral or 1st.
    I just had a brand new ecu put in and it has been driving fine up until now.. Any ideas??
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    If the car wont change into 3rd then the box is probably on the way out. It may be a 1 off - but from what people have reported over the years - when it wont change gears or plays up a little it's time for a rebuild or second hand unit.
    and 3 Dangerous non ABS VN's
    VP Berlina 5.0L
    Nov 2009
    Ah bad luck this same thing happened to mine about 3 weeks ago. There really is no way to tell 100%what the problem is until it's stripped down unfortunatly. If yours is a 304 like mine you're lookin at around $2000 - $2500 mark to get it rebuilt. The v6 ones are a little cheaper. In mine the 3/4 clutches were rooted, there was a bit missing, some hub thing had shattered and found out it only had half a shift kit installed the result of only dropping the pan and some plate thing was drilled to the max diametre (sorry i dont know gearbox parts). But now its all fixed up, definitly money well spent, like driving a different car.
    VP Berlina 5.0L
    Nov 2009
    Oh just on the ECU, being a hydraulic box the ECU plays no part in it. Probs just getting old, if you can afford to get it rebuilt just do it over a 2nd hand unit
    May 2010
    Croydon, Vic
    Had a mate suggest it could be the band on third gear is slipping because it is engaging but will just rev out if told too..
    pain in the ass.. car seems to be off the road more than on these days -.-
    VP Berlina 5.0L
    Nov 2009
    May 2010
    Croydon, Vic
    Burnt out clutch for 3rd gear, new g/box = $300.00 + New race built LSD = $250.00
  1. auto shift kit...?help
    By aussie_cruzin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-03-2010, 11:28 PM
  2. Is it bad to down shift my auto VT?
    By Heffer_Slayer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-01-2010, 10:03 PM
  3. VN Auto shift kit v6>8 help please.
    By K3zBang in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-11-2009, 12:32 PM
  4. shift kit for auto
    By GeorgeB in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-07-2006, 05:40 PM
  5. Vs Auto Shift Kit
    By 64now95 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-10-2005, 07:30 PM
