Hi all my car stalled while driving on the freeway and now wont start I cant hear the fuel pump anymore so I tested it for power and got nothing so I went to check for error codes and to my horror the check engine light doesnt come on anymore I checked all the fuses and swaped the relays with no luck I'm guessing the ecu is dead or not getting power how would I go about testing this?
ps i also tryed overriding the alarm with the glovebox key
the glovebox keys quite often wont turn off and need the wires bridged instead .but ide check that the pink wire at the ecu pin A6 is getting power with ignition on and also that C16 and B1 have constant power
Hi thanks for the reply I will give it a try
ok I tested the override switch with a multimeter it is fine and the ecu power cables are getting power but A6 isnt getting power (tested with igniton on) I have checked all fuses and relays still nothing![]()
pin a6 is feed power via that switch when its turned off stops you needing to press the unlock button to start the car bridge the pinks behind the switch and see if it works or check that the engine loom is plugged into the dash loom properly theres an 8 pin plug not far from the ecu that leads off towards the stearing colomn
the dash is out of the car at the moment i just tryed bridging the override switch and nothing, with the a6 pin not getting power is it ment to get power when the alarm is overridden oh and i might add the anti theft module is out of the car should i put it back in?
turns out it was a broken wire
all sorted
