Results 1 to 5 of 5
Thread: Vn/ve rim tyre question.
    Vl turbo/ vn supercharged
    Apr 2008
    Kwinana, Perth
    Default Vn/ve rim tyre question.
    G'day I have a set of VE commo 16x7 pursuities on a lowered VN, and am wondering if anyone knows the size of the widest tyre thatll fit? I currently have 225/55/16 Tyres and there doesnt seem to b much room before the arch lip? One side looks to have a little bit more room than the other? Cheers.
    lemusa's Avatar
    lemusa is offline Unmotivated Enthusiast
    VN Exec V6 Manual
    Jan 2010
    Christchurch, NZ
    Sounds like you need a adjustible panhard rod, will pull everything back to center. You should get 235's on there no worries, 245's even maybe dependin how low you are
    Apr 2008
    Kwinana, Perth
    Quote Originally Posted by lemusa View Post
    Cheers for that, I do have an adj panhard rod, but have never adjusted one. Looks simple enough. Is there anything I should know b4 doing it?
    VC
    Oct 2008
    Better check the wheels fit before you do anything. VE wheels won't fit a VN.
    To adjust the panhard rod have the car sitting on flat even ground and measure each side wheel arch to rim and make them equal.
    lemusa's Avatar
    VN Exec V6 Manual
    Jan 2010
    Christchurch, NZ
    Good point, to fit the wheels youl need to get them machined 2mm (i think, better check though) down as the ve hubs are slightly bigger
LinkBacks (?)
  1. VE SS Tyre Question...
    By Kierab in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-06-2010, 11:44 AM
  2. Tyre pressure question...
    By anonymousmoose in forum VY Holden Commodore (2002 - 2004)
    Last Post: 04-01-2009, 12:54 PM
  3. rim/tyre size question
    By flyen in forum General
    Last Post: 26-09-2006, 08:55 PM
  4. Tyre Wear Question
    By fixxxer in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2006, 11:00 AM
