Results 1 to 15 of 15
Thread: Engine swap and now new motor wount start
    v6vpute's Avatar
    v6vpute is offline Rolling on stockies
    1993 vp s sedan series 2
    Jun 2009
    Lakes entrance vic
    Default Engine swap and now new motor wount start
    Hey guys i just finished my engine swap everthing bolts up all the wiring in all the light come on when on acc but motor wound start or even turn over could it be a dirty earth?
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    what engine you put in did you modify any wiring?
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VN Berlina
    Nov 2009
    I had something similar. Can't remember what it was, but it was simple. I just metered the wiring from the starter motor back and found it. A simple test is to short out the pins on the starter relay as a starting point. That will tell you a lot. You will need the wiring diagram.
    v6vpute's Avatar
    Jun 2009
    Lakes entrance vic
    I put a series 1 motor with series 2 top half and didnt change any wiring wired up the same way as i undid it as far as i know realy got me stuck with whats wrong
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    Checked all your fuses and relays? Especially the large engine fusible link in the engine bay?
    Just a thought, but is it an auto? Is it in park or neutral when you try to start?
    Illegitimi Non Carborundum
    VN Berlina
    Nov 2009
    You say the motor doesn't turn over when you turn thr key? Then there are 2 circuits ti check. 1. From the key to the start relay and 2. power from the relay to the starter.
    Have someone hold their finger on the start relay while you turn the key. You should feel it click in. If that's OK then it's on the secondary side of the relay.
    You have plugged in ALL the plugs around the battery area. This is where the power goes to the starter solenoid.
    v6vpute's Avatar
    Jun 2009
    Lakes entrance vic
    VS V6 TwinTurbo/VT SS Manual
    Sep 2005
    v6vpute's Avatar
    Jun 2009
    Lakes entrance vic
    vt calais
    Nov 2010
    perth
    if you have a spare wiring loom from the old engine lay it out on the ground and start from one end and go through and make sure you have connected every one . worked for me
    v6vpute's Avatar
    Jun 2009
    Lakes entrance vic
    Well i have the on out of my red vn and the origanal loom was all cut up and thanks for all the help guys
    FXST01's Avatar
    VP V6 Auto Sedan
    Jun 2005
    Quote Originally Posted by v6vpute View Post
    Hey guys i just finished my engine swap everything bolts up all the wiring in all the light come on when on acc but motor wound start or even turn over could it be a dirty earth?
    Is the battery a good one with plenty of charge?
    Try connecting an earth jumper lead from the negative side of the battery to some place good on the motor/chassis and try to start it to rule out crook earth.
    Swapped around some of the relays?
    Is the starter connected? two wires a big red one (bolts on) and a smaller violet one (clips on i think)
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    if the start relay clicks when you turn to crank look at the 2 plugs by the battery that join the engine loom to the relays some models the crank wire is in a different slot
    UNDERCOVER HQ is offline HOT 202
    VN BERLINA 202
    Oct 2010
    townsville
    Mate check the little black lead thats goes from the battery to the car. I have had the same problem.
  15. #15
    v6vpute's Avatar
    Jun 2009
    Lakes entrance vic
    Hey guys got the car working had a earthing problem and broken wire fixed that then the car started sept then the starter motor stoped working properly
  1. Engine Swap V6 S2 motor.
    By VGUTECHICK in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-08-2010, 10:43 AM
  2. wanna swap s1 motor for a s2 motor in a vn
    By Pimpn1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-01-2009, 05:55 AM
  3. 97 vt engine swap now it won't start
    By revvy67 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-10-2006, 05:51 PM
  4. vr engine and box swap, car wont start
    By patl in forum Electrical Wiring / Questions
    Last Post: 18-07-2006, 10:39 PM
  5. vn motor won't start
    By js1978 in forum Electrical Wiring / Questions
    Last Post: 31-08-2005, 09:26 PM
