Doing my heater tap as it leaks, Do i need to have it turned to cold when i remove the old tap?
Cheers guys,
Daniel.
Thanks wortus.
I had to bleed the system when i did the water pump, Guessing this is the same?
Cheers again.
Consider changing the hoses and clamps if they are still original.
Cheers guys, New houses will def be going on.
