Results 1 to 10 of 10
Thread: How do i find an exhaust leak? Is there an easy way to install S1 Vn extractors?
    social's Avatar
    social is offline Commodore Enthusiast
    2006 6.0L VZ Thunder
    Nov 2008
    South Aus
    Default How do i find an exhaust leak? Is there an easy way to install S1 Vn extractors?
    Hey guys,
    Got a problem with the vn (series 1) and cant seem to figure out where the exhaust gas is coming from, i am assuming its where the headers meet the block but cant seem to find the actual leak itself unfortunately. Is there a sneaky way to find it? Have a set of extractors to possibly go on to replace the headers only problem is the series 1 vn's are the biggest head F*** when it comes to removing and replacing, any tips on that also?
    Cheers,
    Social.
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    ve sv6
    Aug 2010
    you can have some one block the end of the exhaust with there hand whilst useing a rag (gets pretty hot) and having a listen.
    Fun_Bucket's Avatar
    Fun_Bucket is online now Gay Country Rapper
    Bumming lifts, saving up.....
    Mar 2009
    Cairns White Rock
    Get your hands on a stethescope, otherwise a bit of hose held to your ear works aswell. Work you way around your bound to find the leak.
    After fitting my new headers i went around and evenly applied some exhaust cement around any gaskets. I was advised that if there was any leaks, that the sealant would turn black fairly quick.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    A combition of the above posts work well have someone block the exhaust and use a piece a hose to listen for a leak.
    I havent fitted extractors to a S! before but i'm sure its very difficult especially on the drivers side getting to those exhaust bolts wont be easy
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    VP Exec
    Jun 2005
    The old trick was to pour or spray a very small quantity of brake fluid into the inlet manifold with engine running. The resulting smoke makes any leak easier to spot. It will work in conjunction with any of the other methods above.
    Do not add very much brake fluid as you can hydraulic lock the engine. Using a cheap trigger sprayer will be safe.
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by Cheap6 View Post
    Can doing this stuff the oxygen sensors at all?I know some silicone products can stuff them.
    social's Avatar
    Nov 2008
    South Aus
    yea i dont think il be pouring any brake fluid into the engine thanks mate.
    VT
    Apr 2005
    QLD
    Apparently the manifolds on the S1 were prone to cracking?
    Fit those extractors.
    All of the aforementioned ideas seem a little quirky lol
    social's Avatar
    Nov 2008
    South Aus
    Il be contacting an exhaust company to install them for me, hopefully not too expensive.. Tried myself and got very frustrated very quickly. Got the gasket for the block to make sure no leaks, unsure if it has one on atm either, and really cbf putting one on if it doesnt or i might aswell do it all myself anyways.
    Besides there up for sale anyways, pending if they sell or not il use them.
    VT II executive V6
    Nov 2011
    there'll be black soot around the leak... very easy to spot
    purrrrrr
  1. Replies: 9
    Last Post: 21-02-2010, 05:49 PM
  2. can't find source of coolant leak, VP
    By Loungefly in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-04-2009, 04:32 AM
  3. cant find water leak
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 21-10-2008, 06:44 PM
  4. Is it easy to install front speakers in 98 VT?
    By JoeFish in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-08-2008, 01:36 PM
  5. How easy? to install the new control IRS
    By Camotec in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 29-03-2005, 08:09 PM
