Results 1 to 6 of 6
Thread: VN aprl90 injector/cylinder probs
    VN
    Nov 2010
    N\A
    Default VN aprl90 injector/cylinder probs
    hey guys/gurls
    was working on my car today and relised that the injector/cylinder 4 and 2 arnt working.
    when taking the injector plug off these 2 then engine doesnt drop in revs like it should?
    any ideas on what could be causing this problem.
    things ive tryed:
    checked the spark plug leads there sparking,
    replace all spark plugs.
    note, im not very mechanically minded im more of a body work/audio lover so any ideas would be great thanks pplz
    vs commodore
    Oct 2009
    Tamworth NSW
    How does the car run,is it misfiring or whatever?Or is it just that theres not much change in the revs when the injector wiring connectors are removed from these two cylinders?
    VN
    Nov 2010
    N\A
    there is no change in in the revs what so ever when i disconnect these to plugs, i ran the dia from the comp and comes up with 12 no problems :/
    any ideas?
    vs commodore
    Oct 2009
    Tamworth NSW
    If you are definitely getting a strong blue/white spark from these two cylinders spark plug leads ,and the spark plugs are new.Try getting a long screwdriver, and with the engine idling,put the end of the screwdriver on the fuel injector body(plastic part) of the two cylinders ,one at a time,and then carefully put your ear up to the handle of the screwdriver,it should work like a stethoscope,you should be able to clearly hear the injector clicking away as it fires.This means its working.The only other thing I can think of is these two cylinders are next to eachother.It could be a blown or leaking head gasket between the two cylinders.Its rare on these motors ,but it can happen.A compression test would be the next step to check each cylinders compression.You can buy a compression tester yourself,or a mechanic should be able to do this fairly cheap.
    VN
    Nov 2010
    N\A
    im thinking it might be the head gasket did the screwdriver test you said to do just now, and there was a strong ticking sound coming through the handle, so guess ill have to wait till tomorrow to get a compression tester and see if thats the problem.
    but if that passes do you have any other ideas on what could be going on, the motor is making a whining sound also, but that might be the power steering unit maybe? or cos its only running 4 cyls?
    also the trans on it is effed, so cant really get the car to a mechanic till i replace that, and personally id rather 'try' fix the problem myself, after all the only way to learn is to do something yourself
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    Try swapping the connectors between 4 and 6, see if 4 will fire no 6 and vice versa. May just be a case of old/blocked injectors.
    Illegitimi Non Carborundum
LinkBacks (?)
  1. intermitting faulty injector circuit on cylinder 6????
    By baracuda in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 25-03-2010, 09:29 PM
  2. leaking injector.. ???
    By westbad in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 05-02-2010, 07:19 PM
  3. Injector Job
    By VNSSMAN in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-12-2006, 09:57 AM
  4. Injector help....!
    By ruredi in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-10-2006, 02:04 PM
  5. Injector help please!
    By Shortstuff in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 11-08-2006, 06:30 PM
