Results 1 to 4 of 4
Thread: vn series 1 sump
    VH SL/E, Chevy Luv, VN S Pack
    Jun 2006
    Default vn series 1 sump
    hey, im just wondering how hard it would be to change a series 1 vn commodore sump gasket with the engine still in the car...???
    i know there isnt a lot of room under there, what would be involved?
    thanks in advance, mark
    Vp Calais charged v6
    Oct 2010
    Melb Vic
    Pretty tricky you will have to unbolt the engine mounts and raise the engine, probably be tricky to do it properly like cleaning the surface and aligning gasket and silicon could get messy but you never no until you give it a crack
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    Heard that you can also jack the engine up a little and drop the k-frame for better access.
    Was in the process of trying to change the sump gasket on a vp v6 as I thought it was leaking. Half way through I discovered that the harmonic balancer shaft had a big groove worn in it which was causing me to lose my vast quantities of oil. Anyway, I got pretty close to changing the sump gasket and I'm glad I didn't have to in the end. Theres not a lot of room down there at all and it would be pretty hard to get it aligned nicely and bolted back on. That said, others have done it so it is possible, it just won't be fun.
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
    Jun 2006
    yeah i thought i might have to raise the engine, and it is the sump gasket that is leaking, ive steam cleaned the engine many times and thats the only place oil is leaking from. i think ill save it for a long weekend....
  1. vy sump
    By s65481 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 29-08-2009, 10:52 AM
  2. Sump
    By madsav in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-08-2009, 09:24 AM
  3. vy ss series 2 front and rear sump leak
    By Jono191 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 28-04-2009, 02:42 AM
  4. Oil Sump
    By AlpineRaven in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-02-2008, 11:43 PM
  5. What is it? under the oil sump....
    By AlpineRaven in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-12-2006, 05:30 AM
