Results 1 to 6 of 6
Thread: Cluster
    VP Commodore
    Feb 2010
    Default Cluster
    Hey Guys,
    Ive got a level 1 cluster and want to upgrade to level 2 coz i want a tacho. is the wiring any different or can i just slip it straight in?
    and correct me if im wrong but:
    Level 1 cluster is just fuel, speedo, and temp
    Level 2 is fuel, temp, speedo and tacho
    Level 3 is like level 2 but has those 3 displays at the bottom
    Also, my odo stopped working. onnce i slip in a new one, will the km's be updated or do i need to wind it manually??
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    You wont need to change any wires going from L1 to L2. The lost K's are lost.
    Level 3 is a bit more involved and needs a switch block and patch loom to make it work properly.
    and 3 Dangerous non ABS VN's
    nstone63's Avatar
    nstone63 is offline wants a new car
    1988 VN Executive
    Mar 2010
    Roxby Downs SA
    Shane helped me out with doing mine, defs worth it now - I love my new one.
    I was thinking, is there anything stopping you from manually winding the odometer forward/back to match your original cluster when you upgrade? Or does manually winding it stuff the board or something? I was thinking of matching my new dash to show what the original km's would be...
    lepht93's Avatar
    lepht93 is offline Well, you're wrong.
    VP Commodore Executive
    Aug 2010
    Eastern Melbourne
    i think you can either goto holden and get them to wind the dash (not sure) but you need to prove it, or somewhere else (but people might ask you to sign a liability waiver)
    I changed mine over to level 2 last week from a VN, the hard way, but yep, all just bolts in and now works perfectly. I didnt bother winding it because the new cluster was only 7000ks less
    Quote Originally Posted by CSP View Post
    Alcohol isn't poison.
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by nstone63 View Post
    Did the voltage regulator fix the cluster up?
    Make a time to come see me next time your down this way and I can fix the odo issue up for you.
    nstone63's Avatar
    1988 VN Executive
    Mar 2010
    Roxby Downs SA
    yeah the voltage reg fixed it up really well, thanks for the help with it. With mine, the difference in KMs was only like 6000 so I'll probably leave it as is
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. Put VR/VS cluster face onto VN VP cluster?
    By vsspack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2010, 04:51 PM
  3. Swapping VR L2 dash cluster with VS Stato L3 Cluster
    By wheredoesthisgo in forum Electrical Wiring / Questions
    Last Post: 07-04-2007, 03:28 PM
  4. Cluster
    By Super Coach in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 27-10-2006, 03:00 PM
  5. Replace VN dash cluster with VX dash cluster
    By Xalies in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-02-2005, 06:55 PM
