Results 1 to 7 of 7
Thread: Whats different from dual fuel engine to fuel engine?
    Ford Xe
    Dec 2006
    Default Whats different from dual fuel engine to fuel engine?
    hey guys baught another vn for parts and its duel fuel..
    however i dont know what parts they change when they do they conversion interally.
    so which parts are different that i cant use on my car which is just fuel
    cheers
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    There is so much wrong with the statement "use on my car which is just fuel".
    cos gas isnt a fuel at all...
    Anyway, a duel fuel might have different heads, springs or valves. usually run a different gap spark plug and bigger leads.
    Thanks about it.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    When people convert to LPG generally its just the LPG gear that is fitted. The engine itself remains untouched.
    Visit my Facebook page
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    You won't be able to use the cylinder heads or valves because they'll be stuffed on a gas powered V6...
    But seriously, not much is changed apart from the gas system itself being fitted as NAAF said. However, I will stand by my first statement, even though it was a bit tongue in cheek.
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    plugs are normally changed then everything that is added for lpg which is obvious to see on motor
    just remember back then lpg still ate valve seats so if your gonna use heads ecpect valves to be shaggeded
    Ford Xe
    Dec 2006
    hey thanks guys sorry for the terminology didnt know how to describe it. i wont be using the engine just everything around it. il be stripping it to if anyone needs vn calais parts
  1. Fuel gauge stuffed? or engine just drinking fuel?
    By Noy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 24-12-2007, 05:51 PM
  2. what engine oil for dual fuel VN
    By andyli in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-01-2007, 08:50 AM
  3. Replies: 6
    Last Post: 25-10-2006, 07:58 PM
  4. Recomended engine oil (Dual Fuel)
    By stew_38 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-10-2006, 01:11 AM
  5. fuel injected 5ltr motor setup for dual fuel
    By ma77es in forum Swap / Wanted to Buy / Trade
    Last Post: 28-05-2006, 07:03 PM
