Results 1 to 8 of 8
Thread: Diff noise..
    VT Series 1 Berlina Wagon
    May 2010
    Croydon, Vic
    Default Diff noise..
    Just had a lsd from a BT1 installed on my commo
    Makes a bit of noise at low rev range with a bit of load under the motor - 4th doing around 70km/h
    Any ideas?
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    jack up rear of car and put on stands then check if the noise can be heard turning wheels by hand
    if hear noise FIND I|T
    if not
    need a hoist to run in gear at that speed and check for noise then you will know where it is comking from and can make an informed decision
    my guess is bearings or plates in the diff if the noise has only just started since fitting it
    May 2010
    Croydon, Vic
    was fitted only a week ago as well as a new box 2 weeks ago.. like i said its only at low rev range it makes the car vibrate but once i increase the revs its fine..
    Theres no noise when hand spinning
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    hmm
    would be checking if everything is tight shafts diff etc
    else if it was a harmonic noise e.g. like a humming might be diff or unbalanced tailshaft???\
    you may need to get a driveline guy to look at it in person
    like a dif specialist to drive it and see what he thinks!~?
    vp wagon
    Nov 2010
    NSW port macquarie
    Vp Calais charged v6
    Oct 2010
    Melb Vic
    Hey buddy if it's a high pitched whine it's generally gear mesh noise from excessive backlash worn gears, Its a common problem it's more common to be the pinion gear bearing to be noisy which is usually more of a rough noise rather then a high pitched gear whine. Both problems need a diffoverhaul I had the same problem in my ex cop vt LSD diff also assuming they had a hard life as cop cars, cheers
    May 2010
    Croydon, Vic
    I found that the issue was solved if i drove the car in 3rd til < 80km/h,
    Issue now is when i take off quick there's quite an apparent noise.. i cant really describe it because its not high pitch whining or gears meshing sound
    I can only describe it as a lurching noise, However it sounds like it's coming from the wheel bearing but if i put my hand back into the centre of the car while driving (on the hump) i can feel slightly more vibration then normal.
    Any ideas?
    VP SS, Cammed VN V6 daily
    Jan 2010
    if you ask me, i would be looking at the diff. If it had no noises after fitting the box, then 2 weeks later you change the diff and something weird happens 9 times out of ten it is those components. check everyting attached to the diff, mainly tailshaft bolts, i've seen similar vibes in a hilux due to tailshaft bolts coming loose. if not maybe and unfortuantly your diff is about to become more expensive.
  1. diff noise...? need help
    By jim vxss in forum General
    Last Post: 10-12-2009, 05:23 AM
  2. diff making a noise / replacing diff
    By yipya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 11:30 PM
  3. VX SS V8 diff noise
    By ozengines in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-01-2008, 09:50 PM
  4. diff noise
    By 20NVY in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-11-2006, 11:37 AM
  5. Diff Noise
    By Mr. Incredible in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-10-2005, 12:08 AM
