Results 1 to 10 of 10
Thread: Ecotec power steering reservoir onto buick?
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    Default Ecotec power steering reservoir onto buick?
    Well long story short, is it possible? Im sick of the reservoir on the buicks cracking so is there a way i could put a vs+ reservoir on? Would also cut out alot of heat soak aswell
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    My tuner has done it on his VN. Mounted the vs reservoir on the driver strut tower. I believe he made a fitting with an o-ring to take the place of where the bottom of the existing buick reservoir force fits onto pump.. if that makes sense? then runs a hose from the fitting to the new reservoir.
    I'm going there tomorrow, i'll try to take a pic
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    I was thinking something along thise lines......
    Had an idea to cut off the bottom of the reservoir that goes into the pump and get some sort of reducer that is the same size converting it to 8-10mm hose... and throwing on a new o ring, dont know how that would go but might be worth a shot?
    If you could get some more info i'd really appreciate it
    89 vn calais v6
    Oct 2010
    the pumps are the same i believe (same mounting and all that) except for where the reservoir connects i guess if you replace the vn pump for a vs pump and find somewhere to put the vs reservoir it could work . im not sure about the high pressure power steering line though. doing the pump isnt to hard. save you stuffing up you're car maybe go to a place like pick a part and take the pump off a vs and see if you can fit it to a vn while you're there. at least if it doesn't work you don't have to put it all back together you can just walk away!
    Dec 2009
    I think Holmart sell both of these pumps. Have a look at the pictures.
    SPECIALS December 10
    They look to be exactly the same like Ryan21 says and not a bad price for a reco pump.
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    WOW they do look exactly the same, Ill probably go to a pick a part when I have a chance and give it a look, thanks guys
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    they are the same pump except the VS pump has a piece of pipe press fit into the body of the pump to fit the hose.
    the only thing that could be a issue is the mounting location of the reservoir, i think it needs to be higher then the pump to ensure the system is self bleeding and no airlocks can occur. but I'll be happy to be proven wrong as I'm intending to do something similar
    Body by Holden, Soul by Brock
    the Legend will live forever
    padrickz88's Avatar
    Dec 2005
    sunshine, melbourne
    Maybe strut tower could be a good place to put it? Will look a little gay but possible?
    Tell me how you go when you do yours
    Apr 2006
    Auckland NZ
    lol, i was planning at moving my PS pump a lot lower like the ecotec pump and then use some sort of alloy reservoir.
  1. Vr Power Steering Reservoir
    By blocka1977 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-02-2010, 09:59 AM
  2. Power steering fluid reservoir in SV6
    By havoc in forum VE Holden Commodore (2006 - ?)
    Last Post: 02-01-2010, 02:06 AM
  3. Empty Power Steering Reservoir.
    By Nurofen in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-05-2007, 09:29 PM
  4. busted up power steering reservoir
    By chevy_big_block_bro in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-08-2005, 06:11 PM
  5. Power Steering Reservoir
    By feistl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-05-2005, 04:48 PM
