Results 1 to 4 of 4
Thread: Nolathane Sway Bar Link Pins For VN
    VN CALAIS
    Sep 2006
    Default Nolathane Sway Bar Link Pins For VN
    Guys- has anyone installed the heavy duty Nolathane pins in their VN? I'm curious as to how people found the extra length of the pins. Looking at mine, they look about 10cm longer than the factory pins.
    The only way I can see them fitting is with the sway bar pivoted up to clear them. Is this the only way around it? I'm guessing the extra length is to suit the revised placement of the sway bar on the VP through to later models but that seems to leave the old VN out in the cold.
    Anyone got any advice? I've currently got some pins on there with the ball joint and want to swap them out for the Nolathane brand pins.
    Cheers.
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    I thought the ball joint type pins were a superior option over the standard bush + pin setup? Aren't they like $200ish from nolathane compared to $50 for the pin and bushes?
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
    wraith's Avatar
    wraith is offline Hand over the dog bikkies
    '95 VR Series II
    Sep 2008
    Demonicaland
    Yes the ball joints are the better option and are indeed more expensive.
    VN CALAIS
    Sep 2006
    The ball joint pins I have are OEM brand ones. They were about $40 each.
    I don't understand why they are so much longer than standard but still recommended for VN.
  1. VT Series II Sway bar link pins
    By TGibson in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 21-10-2011, 07:01 PM
  2. Sway Bar Link Pins
    By MILD in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-10-2010, 10:27 PM
  3. removing sway bar link pins ?
    By mking in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-10-2009, 04:37 PM
  4. Sway Bar Link Pins
    By mischa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-12-2008, 02:22 AM
  5. nolathane sway bars
    By r_i_d_a_h in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-03-2007, 09:28 PM
