Results 1 to 21 of 21
Thread: Speedo still not working?
    lepht93's Avatar
    lepht93 is offline Well, you're wrong.
    VP Commodore Executive
    Aug 2010
    Eastern Melbourne
    Question Speedo still not working?
    Hi,
    I changed my speedo to level 2 the other week, finally got the spare on yesterday and took it for spin, my previous L1 cluster worked fine except the speedo, so i replaced it with a L2, and the speedo still doesnt work in a 0-20kmph range, it started workign when i took it for a spin and revved it ahrd and got to maybe 30kph and it showed up, then again i did give it a whack before, but still doesnt work at low speeds?
    Also, this new dash, the trip meter and odo dont work.
    Any idea?
    I checked the voltage thingo teeth when i replaced it and they all contact fine.
    thanks
    Quote Originally Posted by CSP View Post
    Alcohol isn't poison.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Sounds like the Vehicle speed sensor is on its way out
    As for cluster sounds like you have a level3 with lcd screens? if its level 2 then itd be the fact the speedo doesnt work
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    As far as I knew the odo and trip meter don't work when the speedo doesn't work as they run off the same electrical current? That would also help explain it if the odomete cog teeth are all intact.
    Could be the speed sensor down on the back of the trans, when mine started to go it wouldn't work at low speeds, then it eventually would only randomly work every now and then until it stopped all together.
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
    D3V14NT's Avatar
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    lepht93's Avatar
    Aug 2010
    Eastern Melbourne
    No i definitely have a level 2, by trip meter i mean the thing with the set button that resets it.
    how much is it to replace a speed sensor can it be done at home?
    D3V14NT's Avatar
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    I got a second hander for $40 from the wreckers. Its a pretty easy job if you've got car ramps or axle stands, just need to get under the car and undo a couple of screws (or bolts, can't remember). When your under there it's at the rear end of the trans on the passenger side, wires coming out are dead give away.
    1. 1990 VN Exec V6
    lepht93's Avatar
    Aug 2010
    Eastern Melbourne
    and what about the copious amounts of trans fluid that will piss everywhere :P?
    D3V14NT's Avatar
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    stuff all came out of mine but I had the back up on ramps so that it would have all pooled at the front of the trans
    1. 1990 VN Exec V6
    lepht93's Avatar
    Aug 2010
    Eastern Melbourne
    well, i guess i could just put a tray underneath it haha.
    question,
    if i do a diagnostics, and the VSS is needing relacement, will i get a code 24?
    If i dont get a code 24, is it not the VSS
    VP Exec
    Jun 2005
    The speed sensor only has to be unscrewed, no tools required. That + the white plug and it's out. There shouldn't be any fluid leakage either, although there may be a few drips.
    Code 24 sets under fairly specific circumstances; no speed signal with a MAP (manifold pressure) signal that indicates an engine vacuum that can only be achieved under decel., for a certain period of time (a few seconds). The code will not always set if the speed signal is only intermittent rather than completely absent. Worth trying the sensor I think.
    lepht93's Avatar
    Aug 2010
    Eastern Melbourne
    I just don't want to spend money on something it isn't, but of you guys are pretty sure then I guess it's worth a shot
    D3V14NT's Avatar
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    Do you have any mates that you could 'borrow' a sensor off to see if that is the problem. Shouldn't be a big deal to take their car off the road for 30mins while you test it out and it saves having to buy one until your certain.
    Cheap6 is right about the code, it does need some pretty specific conditions to set it off. Drove around with a barely functioning speedo for 4 months before the code was set haha.
    1. 1990 VN Exec V6
    D22 St-r Navara
    Dec 2010
    perth
    im getting this same problem on my mates car . lvl3 speedo and trip doesnt work . speed sensor is new and works on another car , same with the cluster but just not in his. all wires intact and connected so im pretty well stumped. any ideas?
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Quote Originally Posted by Krisp View Post
    Do you have an ODO reading? if not the trip computer is not getting 12 v via the orange white/black white wires. Are the dash plugs in the correct way? If a plug is upside down it will do silly things.
    and 3 Dangerous non ABS VN's
  15. #15
    VS Berlina soon to be 5L
    Aug 2010
    Girrawheen
  16. #16
    D22 St-r Navara
    Dec 2010
    perth
    Quote Originally Posted by 88GreenVN View Post
    all the plugs are the correct way it started with the tacho dying and the speedo being intermitted. you would hit a bump it would die , hit another it would come back on . to the point where no matter what you did it wouldnt work.
    jacko84 the speedo sensor is new works in all cars but this one
  17. #17
    D22 St-r Navara
    Dec 2010
    perth
    after sum reading it could be the bcm thats one thing i havent fiddled with
  18. #18
    88GreenVN's Avatar
    Jun 2006
    If the tacho and speedo are "dropping dead" in 1 car but work fine in another then it will be the wires of the main loom. The L3 cluster gauges and the L2 gauges run off the same wires so it's not the L3 upgrade wires. you should be able to run a L2 dash and get the same thing happening that you are getting with the L3 cluster.
  19. #19
    D22 St-r Navara
    Dec 2010
    perth
    yes lvl 1 and lvl 2 have the same effect might rig it up tomorro have the car idling , and wriggle the rear connections to see if that changes anything
  20. #20
    88GreenVN's Avatar
    Jun 2006
    The purple white wire is the speed signal. Brown red is the tacho from memory.
  21. #21
    D22 St-r Navara
    Dec 2010
    perth
    well i pulled it out (the bcm) replugged it in and tacho / speedo now work a treat. cheers for the help green
  1. VL Speedo not working
    By kapooka in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-11-2009, 07:44 AM
  2. Speedo not working
    By stocky in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2009, 06:12 PM
  3. Speedo Not Working
    By Crossy_014 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 31-05-2009, 07:31 PM
  4. speedo not working
    By adrihack in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-04-2009, 03:36 PM
  5. Speedo not working
    By holster in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-10-2005, 11:01 PM
