Results 1 to 10 of 10
Thread: Vr Manual to vp Auto Conversion
    1992 VP Holden Berlina V6
    Nov 2010
    Rockhampton
    Question Vr Manual to vp Auto Conversion
    Hi, I recently bought a vr v6 manual gearbox and ecu with gearbox wiring and all the associated parts to bolt into my vp v6. I have a query regarding the gearbox wiring. What ecu should I use with the manual and also since my vp is auto and I have the vr manual wiring how do I wire in the speedo and reverse lights?
    Will I need to change the ecu in my vp to the manual ecu supplied with my gearbox? will the car stall out at idle with the manual? I hear that the vp auto and manual used the exact same ecu so if this is true then I should only need to wire the speedo and reverse light switches and not have engine MIL issues or dtc's. Please help me as I am desperate to start the conversion
    Thankyou
    Wayne
    social's Avatar
    social is online now Commodore Enthusiast
    2006 6.0L VZ Thunder
    Nov 2008
    South Aus
    shouldnt be a problem mate, if u have an auto ecu in a manual i believe it thinks its just forever n neutral and oif they are both swappable u shudnt have a problem.
    Quote Originally Posted by Shooter03 View Post
    Washed it and now the wife's gonna take it out and get it dirty.
    Quote Originally Posted by QldKev View Post
    You are talking about the car?
    Nov 2010
    Rockhampton
    hi thanks for your reply on this subject. I hope that it all works for me and the only stress is my speedo and reverse lights cheers
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    To get reverse lights working you'll need a manual short wiring loom these plug from gearbox into main harness. I think this also covers the speedo been a while though
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    Nov 2010
    Rockhampton
    Nov 2010
    Rockhampton
    Default manual memcal
    Need urgent Help, I have been into holden and looked at the part numbers for the manual and auto memcals and they are different. The thread on here about vn-vp manual conversions says I need a manual memcal or have my vp memcal reprogrammed. The kit from the VR I bought comes with the ECU from the VR and has the Manual memcal fitted in the ecu. my vp has a standard ecu with auto memcal. other than the instalation of my conversion to manual, only the memcal is stressing me out. What do I need to do to make the engine work with a manual box, what memcal do I need to run?
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    MATE calm down.....
    OK now listen dont worry about holden they have no idea they told me you cant buy an oil pump anymore.
    You do not i repeat do not need a manual ecu or memcal in fact i ran a VP manual ecu and memcal in a S1 vn with an auto.
    The only VR onwards need a manual ecu memcal and wiring loom BECAUSE they have an electronic auto which is controlled by an auto ecu. If you were to put a manual in theses models without changing them the ECU goes WTF theres no gearbox !!!
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    Quote Originally Posted by bobby_wayne View Post
    If you are running the VR ECU and VR memcal, you will need to have the memcal reset to 1250.05 (KSPDSENA) for the speedo.
    Added: If using VR memcal will also need to turn off the VATS the anti theft setting. Although I think you can use a VP memcal in a manual VR ECU.
    Illegitimi Non Carborundum
    Pub247's Avatar
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Stuff that sell the vr memcal and ECU they're worth a mint cause theyre rare and use the vp one. Also a VR ecu wont work/fit on a vp loom and engine anyway
    FXST01's Avatar
    VP V6 Auto Sedan
    Jun 2005
    Quote Originally Posted by Pub247 View Post
    A VR manual ECU is straight plug and play, a VR Automatic ECU causes magic smoke to come out.
  1. PCM BCM vt auto to manual conversion PLEASE
    By bencbh in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-11-2010, 02:47 PM
  2. Please Help, Doing manual conversion and i used the auto flexplate bolt on manual fly
    By xtreme_sony in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-06-2009, 08:52 PM
  3. VY L67 Auto To Manual Conversion (And More)
    By alien in forum VY Holden Commodore (2002 - 2004)
    Last Post: 27-05-2009, 10:12 PM
  4. Auto-manual conversion
    By White202 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 08-09-2005, 10:13 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
Tags for this Thread
