Results 1 to 5 of 5
Thread: VP Overheating before & after new engine Help !!!!!
    VN HSV SV-50 Commodore
    Sep 2008
    Default VP Overheating before & after new engine Help !!!!!
    Hi there,
    My girlfriends vp v6 was overheating so i flushed the system, but it didnt fix it, We took it to the mechanic he said new heads $1700 anyway we got a 2nd motor from wreckers fitted & guess what ??? Yep the temp sits on 1/2 then at lights nearly goes to red after spending $1000 Im out of options please help cheers Scott
    LordMayhem's Avatar
    LordMayhem is offline Here For A Good Time!
    VN Calais
    Jan 2009
    Hervey Bay QLD
    make sure the thermo fan is working. is a common fault for it to fail. if it has just wire it through the ignition and a relay so it is always on when ignition is.
    VN Calais With All The Factory Fruit I Need!
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    To test the thermo put the vp in diagnostic mode the thermo should come on when ignition is switched on. This will tell whether the fan is working or not.
    Ignore the above post go to the how to section of this forum and look for
    "how to wire a thermo fan bypass switch"
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    Dec 2009
    I'm with Pub247 I wouldn't be rewiring it so that the fan is always on, Have you checked your temperature gauge to make sue that it is working properly? The fan will or should come on anyway when you turn on the aircon, give that a try does it still overheat?
    Apart from that I am assuming that the new motor came with it's water pump etc? This means the fault is with something that was not changed, hence the suggestion of a faulty gauge or failing that your radiator may have a blockage?
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Thermostat is jammed, only letting a small amount of flow thru, had 1x on my VP when it sat for a month at the repairers
    New wrecker special has prob been sitting for a bit, it allows for flow but restricts it heaps, causing temp to rise
    ________________________________________
  1. Engine overheating.
    By boohsv in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-10-2009, 10:54 AM
  2. Engine 'saying' its overheating
    By Chalky01 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-10-2009, 11:49 AM
  3. Engine Overheating
    By dazamaz in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-07-2006, 07:41 PM
  4. engine overheating?
    By fullaaa in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 22-03-2006, 02:04 PM
  5. Engine Overheating
    By noddy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 10-06-2004, 09:44 AM
Tags for this Thread
