Ok, so after running the car until it overheats I've checked relays and fuses which are ok. Next I hooked up the fan to an external power source and it works. I then checked the termo element at the rear of the engine via a multi meter and some boiling water and it gives a reading.
Is there something I'm still overlooking?
Also can I hard wire the fan in anyway (until I can $$$ for repairs)?
do a search for "how to wire a thermo fan bypass switch"
As said above in dact there a thread in this section regarding same sort of issue in which i posted some info.
Put the car diagnostics mode see if fans comes on it should if not then theres a wiring issue of some sort.
If you have checked all the wiring and fan doesnt come yet it works as you stated i'd be suggesting try replacing the ecu with a knnown working one and see if it works then
Originally Posted by Smidy
Hey man I think maybe change your temp sensor unsure in the vn's if there are two, one at the front of the engine and one at the back the one at the front is right behind the alternater.
Agreed with pub247- I had a similar prob few years back, turned out to be ecu computer
are you in perth? i have an ecu you can check with
