Results 1 to 6 of 6
Thread: Oil pressure gauge malfunction?
    VP
    Nov 2010
    Cool Oil pressure gauge malfunction?
    Hey guys me and my missus own a 92 VP, just drove over the nullabor, had no problems. Changed spark plugs after 3000 km's and have had no dramas until yesterday. The pressure gauge is going off the dial past 50 psi, way past, and all the way back to 10? Oil level is fine. She is running hot and smelling a bit but temp gauge is ok? I do most of the work myself and know a bit but this has got me baffled. Can anyone shed some light on the problem? Looking forward to hearing from someone soon. Cheers guys. Damo and Faye.
    UNDERCOVER HQ is offline HOT 202
    VN BERLINA 202
    Oct 2010
    townsville
    Default Oil
    YOU COULD TRY CHANGING THE OIL PRESSURE SWITCH SEE IF THAT MAKES A DIFFRECE.
    Pub247's Avatar
    Pub247 is offline Donating Member
    92 VP wagon Daily
    Apr 2006
    Melbourne S.E.
    Um which gauge are you refering to? there is no factory oil pressure gauge on a vp only a low pressure light. I'd be worried if i wasnt getting over way over 50psi oil pressure should be about 80psi above 2000rpm and half that at idle
    Quote Originally Posted by Smidy
    How many kw would i need to beat vin diesil to the train lines?
    Vee-ard's Avatar
    Vee-ard is offline QuickVR95II 2010 Survivor
    Foam Tuned VR 5.0l Ute
    5 Miles 2 Go Champion!
    Jun 2009
    Bayswater, WA.
    Quote Originally Posted by Pub247 View Post
    Have you even got one installed to know what they sit at?
    Pretty sure 80PSI is close to spinning bearings mate. Mine idles at 10PSI and cruises at 40PSI can get to about 75PSI if i flatfoot it. which is normal for 5.0L's, they run pretty low pressures, especially at idle.
    Infact the repair manual states idle pressure to be 48kPa (7 PSI) at 500RPM and between 275-414kPa (40 PSI - 60 PSI) at 2000RPM at operating temp on a V8.
    The V6's are 275kPa @ 1850 RPM.
    Damo, check that the signal wire from the sender isnt shorting to anything. if it earths you'll get max reading.
    The hall of fame:
    Quote Originally Posted by lindsay.VS.Wagon. View Post
    ....a mini spool creates greater airflow to the engine which means more oxygen into the engine which adds greater combustion which adds an all around performance upgrade.
    Quote Originally Posted by edals View Post
    Also found running your lights all the time looses 100kms to a tank also.
    ಠ_ಠ
    VP
    Nov 2010
    VP
    Nov 2010
    Thumbs up
    Cheers guys I'll check its not earthing, I know VP's didn't come with an oil pressure gauge, its after market. Basically apart from the chassis and body the whole thing has been replaced with HSV. Only a six but chipped up, Extractors, the usuall fruit so the whole dash and gauges are HSV... gonna go sus it out. Will let you's know.
  1. Oil Pressure Gauge - SIC
    By fanez in forum VE Holden Commodore (2006 - ?)
    Last Post: 03-08-2010, 11:37 PM
  2. oil pressure gauge
    By mking in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-07-2010, 06:04 PM
  3. Oil Pressure Gauge
    By My Car in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-01-2009, 10:15 AM
  4. HELP oil pressure gauge ?
    By Lazin in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-05-2006, 02:02 PM
  5. oil pressure gauge, oil pressure
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2005, 10:31 PM
