don't have much idea when it comes to tire size, but, my current tires are 205/65R15
I understand the width and the diameter, just not 100% if these tires would fit on 15x7 interceptors?
Thanks
You want to fit these tyres which are 205 mm or 20.5 cm wide,onto 7 inch or 17cm wide rims.Id say they should easily fit,but Im not a qualified tyre fitter so Im not absolutely 100% sure.The guy that fits them for you should be able to tell you strait up whether they will or not..
If you go to the web site of the company who makes the tyre and look at the specs/info on that tyre they usually say what range of rim width's the tyre will fit onto.
dude the standard tyre size for a 15 inch commodore wheel is 205/65R15 so why wouldn't they fit? you can run 225's down to 185's if you want. just confirm with your tyre shop first or look at the tyre placard fitted to your vechical there either in the engine bay (VN VPs) or on the driver side dorr (VT n up)
I have just recently swapped my 205/65/15 tyres from 15x6's to 15x7 rims...they certainly fit how ever they dont look as good as they did on the 6 inch rims....need a wider tyre, maybe 215/65/15 or 225/60/15...
Dazz
VN BT1 Mock Up Commodore
Dynamic Locksmiths
sweet thanks guys
