Results 1 to 4 of 4
Thread: LPG Conversion
    VN Commodore
    Nov 2010
    Tahmoor NSW
    Default LPG Conversion
    We are fitting LPG next year and i believe the leads should be changed to give better spark. can anyone recommend the correct leads.
    At the moment the leads on car are Bosch Super Sports Inductive core 784.
    I think mine is a S2 As it has seperate coil packs, thermostat at the front of engine and radiator cap and overflow bottle.
    The build date says FEB 91. axle GU4, TRANS MD8 (manual at the moment), ENG LG2.
    I have seen some heavy duty gas leads on epay, has anyone used them?
    vn commodore s2 BT1
    Mar 2010
    i got 8mm leads and platinum plugs and there fine try the h d ones let me know how they are
    VP Exec
    Jun 2005
    With one exception (Repco branded when I couldn't get genuine), I've always used standard leads and plugs, standard gaps without any problem. I do change the 'plugs and check the leads at the recommended 20K km.
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    For best advice, consult the Auto Gas Fitters/Installers (who will be doing the job - as they have to be licenced) as they would have the best available knowledge for their installation.
  1. L67 conversion OR 5L conversion in vs commy??
    By triple b in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-08-2010, 11:54 PM
  2. electric window conversion successful next climate control conversion
    By bhopper in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-07-2010, 06:22 PM
  3. Vs dash conversion - Firewall - ecotech swap - vs stato front end conversion
    By vnsmanual in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 06-06-2010, 10:51 PM
  4. conversion people conversion
    By flynn84 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-09-2007, 01:25 PM
  5. Vp manual conversion and vn auto conversion
    By gumbs in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-06-2005, 11:08 PM
