Page 7 of 7 FirstFirst ... 34567
Results 151 to 153 of 153
Like Tree1Likes
Thread: Solution to Sticky fuel/temp guages
  1. #151
    VT V6
    Mar 2005
    Perth..
    Worked a treat on my VP cheers!
    Its just a V6.....
  2. #152
    VY Acclaim wagon VP EXcective wagon 2x56 Chevs
    Dec 2010
    St Clair
    Quote Originally Posted by chevyshubox View Post
    Just did the resolder to the voltage regulator and both Temp and fuel gauges seam to be working fine. I also did the odometer gears while I was at it and now the odometer works perfect. I found that both gears on the odo where still in perfect condition with no teeth missing but it sometimes didnt work so I changed them anyway and so far so good.
    Just thought I would update. My temp still works fine but my fuel gauge stopped again and would only work if I hit the dash so I had a look on ebay and there was a brand new VN gauge for $50.00 so I bought it and now my fuel gauge never sticks.
  3. #153
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    It looks like if your tried all the soldering on the votage regulator, cleaned the rest stop pin of any goo and lubed the needle point and the gauge still sticks, it is cacktus for sure. I've binned about 20 gauges todate when they dont budge for more than 8 seconds on the test bench. Four seconds should see the gauge move off empty after all the service work you can do.
    and 3 Dangerous non ABS VN's
  1. sticky guages
    By andyman in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2007, 08:22 PM
  2. Easy solution to sticky needles?
    By mouce in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 29-06-2006, 08:33 PM
  3. Sticky Fuel & Temp Guages
    By Harvs82 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2006, 09:27 AM
  4. sticky fuel & Temp guage
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-09-2005, 10:48 PM
  5. aftermarket temp guages
    By dagsy in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 19-08-2004, 11:10 AM
