Results 1 to 6 of 6
Thread: Thermostat help
    89' VN Calais. 99' vs statsman sIII
    Jan 2010
    Default Thermostat help
    Hey all just wondering on the vn engine were the thermostat is on the rear of the engine does the housing hav one or two bolts holding it together?
    Thanks
    vpcalais6's Avatar
    vpcalais6 is offline F#%ING [P] PLATER
    V6 manual vp Calais
    Sep 2007
    central coast
    Just the one bolt mate
    CHEV badges Australia says no
    fighting online is like racing on a special olympic. Even if you were to Win! your still ####ing retarded
    Jan 2010
    Iv been told that the housings fuse 2 the manifold? Is this tru i removed the bolt and couldnt get it out so thought id leave it till a day were i had more time and i think if accendently crosstheaded the bolt its tight but u can still move the washer with abit of force is is still ok 2 drive 2 work and back or should i get it fixes asap? I ran the car till the thermostat opened nd had no leaks but im still worried bout it
    vpcalais6's Avatar
    V6 manual vp Calais
    Sep 2007
    central coast
    Yeah that is true they take a bit to get off I would still drive it check for leaks often but I would still get it fixed asap
    Jan 2010
    Gettin it done 2 moz u rekon its gona cost much for them 2 fix my stuff up with the cross thread? Its not bad i stopped wen i noticed wat happened
    1992 VP Holden Berlina V6
    Nov 2010
    Rockhampton
    Just buy a tap the same size as your bolt and do it yourself Bunnings even sell tap and dye sets
  1. Thermostat .....i think??
    By markandsam in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-06-2009, 10:05 PM
  2. Thermostat
    By Leebo in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-05-2009, 05:26 PM
  3. Which way does the thermostat go? + highflow thermostat?
    By thek in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-02-2009, 11:11 AM
  4. is it my thermostat
    By 5.0L UTE in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-07-2008, 04:05 PM
  5. thermostat
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-10-2006, 10:48 PM
