Results 1 to 8 of 8
Thread: Level 3 cluster beeping.
    Series 1 VN Executive wagon
    Jun 2010
    Angry Level 3 cluster beeping.
    Hi all. This is my first thread so bare with me. I've got an '88 exec', v6, 5 speed wagon. I recently fitted a level 3 cluster and trip computer switch block. All modes appear to be working fine. During the week it started to beep when first taking off. Then every couple of minutes after that. NO warning light on dash anywhere. I got home and traced all wiring and it appeared that the wire from connector 4 to the computer wasn't connected properly. fixed it, started up and drove up driveway. NO beeping. Cool. Then on Thursday the tacho started to play up by only working intermittently. Belted the dash, no difference. Decided to change the coil and bingo away it went..BUT now I've got the beeping back again same as before. I've just spent half the day checking all wiring, modes and even changing the speedo sensor on the side of the gearbox but the F*%king beep is still there. I put a series 2 coil pack on the old girl. Surely that's not the problem. Any ideas or help with this would be greatly appreciated. Cheers, Bill.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    What does the beeping sound like, if you can describe it?
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    Jun 2010
    Default level 3 cluster beeping.
    hi mate. it beeps 7times each time. first 2 beeps- one higher pitched than the other then 5 quick beeps all the same higher pitch.
    SS VN, VR Berlina
    Feb 2010
    New Zealand
    Jun 2010
    Lightbulb
    haha.. nope. but tomorrow I'm going to take the cluster back out to check that the rolled over tabs in the plug slots aren't cracked or broken. a signal isn't getting through somewhere--Obviously. I even swapped computers and a third coil pack.
    S/C VN, VY SS, Waverunner GP1200
    Dec 2005
    S.A
    For everything regarding Level 3 clusters, checkout this site:
    level3patchlooms - home
    More than likely, it's a cracked voltage regulator causing the handbrake warning to beep. I use to have the same problem until it was replaced
    Jun 2010
    G'day there. By 'voltage regulator', do you mean the copper trace lines in the plastic circuit board? I reckon that's what might be doing it. I've had the cluster in and out a few times when wiring up etc. so i suspect a broken one. if so I may have to have to run a wire from the back of the loom plug to under the warning globe for the handbrake. I can't see myself getting a new blue circuit board to easily. Thanks for the replies..to all..
    Jun 2010
    Ok guys. I found a thread on voltage regulators...######## me should've realised sooner what and where it was. I'll have a go at it this week ..thanks again for all replies.
  1. Installing A Vr Instrument Cluster Into A Level 1 Cluster Vn Exec
    By badly_drawn_boy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 01-07-2011, 02:41 PM
  2. Strange things after changing from VN Level 1 cluster to VP Level 2
    By vsspack in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-03-2010, 09:45 AM
  3. Dropping Level 3 Cluster into unready Level 2 ready VS
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-01-2009, 03:56 PM
  4. beeping in the cluster
    By slipstream001 in forum Electrical Wiring / Questions
    Last Post: 16-11-2007, 02:57 PM
  5. How do I fix the handbrake beeping on my new cluster
    By gdunkley84 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-01-2006, 06:02 PM
