Results 1 to 9 of 9
Thread: vs kframe and suspension into a vn can it be done has any one done the modification
    vn 5litre 5speed
    Nov 2010
    brisbane
    Default vs kframe and suspension into a vn can it be done has any one done the modification
    Hi has any one done this mod before or know if it can be done thanks jeff
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    I know the k frames are interchangeable but the i don't know if you can bolt the rest up because of the different strut tops?
    vn 5litre 5speed
    Nov 2010
    brisbane
    was thinking of changing the strut tops for the vn only thing i was worried about was what is all the extra bolts on the strut top of the vs are the there for strenght or as i have heard to help keep suspension alingment better than the vn it looks like it will all fit otherwise 2 cars side by side and compared any more thoughts thanks jeff
    vz wagon
    Aug 2006
    Wild west of Melb
    Just put the strut top off the vn on the vs strut as they bolt up different at the bottom dont they ?
    ve sv6
    Aug 2010
    the hole size in the bearing is different between vb-vp 14mm to vr-vs 16mm, so unless you can set the strut up in a lathe to take 2mm off the spiggot diameter you wouldnt be able to use the early bearing plate, unless you can change the bearing in the early bearing plate for one with a bigger id,if you could do any of those it would fit but dont know how it willl effect the track, might make it wider.
    vn 5litre 5speed
    Nov 2010
    brisbane
    Default thanks
    Quote Originally Posted by Clutchy View Post
    thanks im was using the whole vs kframe and strut set up fully changing but looks like the bearing size on the top plate is different
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    Quote Originally Posted by glenn l View Post
    im going to be putting a set of adjustable VN strut tops into my VR so will have to get the bearing pressed out and also have to make an adaptor plate to bolt up to the chassis.
    also, VR/VS K frame has wider mounting points for the lower control arms, And longer lower control arms. you MIGHT be able to use VR/VS control arms combined with VN struts but not sure. it would still kick out the front track pretty massively. put it this way, stockies were sticking out of the guards on my VN and i had a VL RB30+kframe + VR control arms+struts in unless i made it have demon camber to bring the top of the tire back under the guard.
    EDIT: whats your reason for wanting to do the conversion? if its just a suspension reason it wont be roadworthy due to the increased front track, and if its an engine swap reason, both buick and ecotec mount the same.
    ve sv6
    Aug 2010
    Quote Originally Posted by klampy View Post
    you know you can get vr-vs adjustable top mounts.
    VR V6 turbo 4speed
    Sep 2007
    coffs harbour
    yea, but on an incredibly tight budget and already have the vn ones.
  1. [VIC] wtb v8 kframe and radiator
    By pow3rslave in forum Swap / Wanted to Buy / Trade
    Last Post: 08-07-2009, 04:05 PM
  2. v8 conversion parts - motor box ecu loom kframe tailshaft lsd
    By petezor in forum Swap / Wanted to Buy / Trade
    Last Post: 16-04-2007, 10:13 AM
  3. kframe change over
    By DANNY8 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 16-01-2007, 08:54 PM
  4. For Free: VN V6 S1 Motor still on kframe with control arms!!
    By rian in forum Parts And Other Items For Sale
    Last Post: 26-10-2006, 05:28 PM
