Results 1 to 7 of 7
Thread: VR SS Drop Tank Into VP
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Default VR SS Drop Tank Into VP
    Hey all
    got me a VR SS drop tank, straps and little stone guard.
    Its got an in tank pump
    How should i go about installing this?
    Should i replace some lines while im there?
    Do i need to replace the pump?
    VKC
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    Dec 2009
    If it's an in tank high pressure pump and not just a priming pump then you won't need to change it. If it's a priming pump you may be able to fit a high pressure pump with some mods to the pickup or you may need to get an ou tof tank high pressure pump.
    You may also need to look at your breathers as from memory VN's have 3 on the top and VR/VS has only 2 bu tI am not 100% sure on this I am only going by what I saw in a wreckers a while ago when I was after a tank for my VN.
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    OK
    thanks mate..
    How do i know if it is a high pressure?
    Dec 2009
    the high pressure pump is longer and there is a pulsator which I don't think the priming pumps have.
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    OK, Ill take a look, I tried to get the pump out, got it about half out, gave up and tried to put it back, But it wont sit flush now?
    Dec 2009
    Quote Originally Posted by VKCOMMO View Post
    Yoiu may have got the fuel gauge float caught up in the hole in the fuel tank. You have to wiggle the assembly a bit and take the float out first. What's happened when you have put it back is that it's not sitting ion the swirl pot properly and you have to kind of rotate it while your refitting it, it's been ages so I can't remember which way
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    OK, Ill take it out and try again..
    Thanks
  1. Drop Tank.. Lowering Petrol Tank..
    By anton1o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-05-2010, 05:52 AM
  2. Drop tank!!
    By [SIK-GMH] in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-05-2008, 07:26 PM
  3. vk drop tank
    By iosexy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-04-2007, 05:35 PM
  4. VP ute drop tank
    By hispeedvp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-07-2005, 01:43 PM
