Results 1 to 19 of 19
Thread: question about my vp?
    96 Vs
    Feb 2009
    Default question about my vp?
    hi all. looking for some advice... for some reason my 93 vp has started playing up out of no where. the car starts and idles fine in all gears. also revs up with no problem but as soon as i accelerate in either drive or reverse the car splutters and coughs... runs like crap. ive checked the spark in the leads and plugs but it all seems fine.. i cant work it out so can anyone help me out with some info please?? cheers
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    could be fuel related, do uno when fuel filter was last changed?
    ________________________________________
    Dec 2009
    Quote Originally Posted by 1996_Vs_Commodore View Post
    Check the spark plug lead resistance. I had a similar issue and a lead was open circuit, it only broke down under load.
    96 Vs
    Feb 2009
    thanks for your replies guys ill check them all out now.... ill keep ya's posted....
    96 Vs
    Feb 2009
    ill be checking the fuel filter/replace it when i find some ramps. as for the leads, how do i check the resistance? they are all in good cond. no burns or holes or aanything... ill replace them anyway. cheers
    96 Vs
    Feb 2009
    D22 St-r Navara
    Dec 2010
    perth
    96 Vs
    Feb 2009
    D22 St-r Navara
    Dec 2010
    perth
    its enough to keep the car idling, but cannot cope with the demand for more fuel, hence the spluttering
    Dec 2009
    To check the leads you take them off and use a multimeter measure their resistance, there is a maximum resistance allowable for both the short and long leads. I can't recall off hand what they are.
    Just to clarify the car splutters and coughs only while your accelerating or does it do it at constant speeds? If it's just while accelerating check your throttle position sensor and the plug on it's wiring.
    The TPS also has a resistance range and a set rate of change of resistance and these must be in spec.
    If you have changed the leads and fuel filter and fuel pump and the TPS is OK then you will need to start looking at the coil packs, DFI and the associated wiring/plugs etc.
    96 Vs
    Feb 2009
    havent one the fuel pump yet..... but ill look into that.... thanks for the advice guys...
    96 Vs
    Feb 2009
    D22 St-r Navara
    Dec 2010
    perth
    96 Vs
    Feb 2009
    id say so..... id everything and now it runs smoother than before... cheers for your help mate.
  15. #15
    vp executive s2 v6
    Dec 2010
    bundamba
    i had the same problem,my fuel pump died and i got it fixed,i was fine for a day or two till it started aging so i then changed my fuel regulator,and i aint had a problem,its has now been a month
  16. #16
    96 Vs
    Feb 2009
    now i seem to hae a problem with the transmission..... i have to rev it around 3000rpm to move in reverse(slowly) and it stays in first longer than its ment to(still changes to second)...... could this be the torque convertor is stuffed or just the bands need tightning????? or do i need another box??
  17. #17
    91 vn s
    Jun 2009
    Adelaide, SA
    might sound a bit obvious but check your autotrans fluid. It needs fluid to move anywhere, so it might be low, hence not moving anywhere in a hurry
  18. #18
    96 Vs
    Feb 2009
    the fluid level was dine when the car is cold. but i checked it when i let it run for a bit and it was real low so i topped it up and it now runs sweet lol... my mistake...
  19. #19
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Yeah have to check the trans levels while the car is running, best to run it thru the gears before u check too.
    I must check mine, been over 3yrs since i did a service
  1. yes no question
    By PSYKO PHOENIX in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-02-2009, 02:08 PM
  2. Ebay question.... moral question?? lol
    By NORTI in forum The Pub
    Last Post: 03-04-2007, 03:43 PM
  3. HSV question.
    By vtdemon in forum General
    Last Post: 26-01-2006, 10:46 AM
  4. Question VZ Ute SS
    By bru78 in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 15-12-2005, 10:41 AM
