Results 1 to 4 of 4
Thread: vn calais troubles
    hz tonner, vh wagon
    May 2010
    Default vn calais troubles
    hi boys went out and brought a 5 speed vn calais on the weekend, to do up for my P's, was a 5ltr but it is now a 5 speed v6, worked engine not to sure whats been done but acording to the old man and the last owner it goes pretty hard and wants to get side ways alot, been set up for 20's camber and all that shit to suit, mixed body kit from three diffrent cars looks tuff.
    anyway way im having a few problems with it, first the engine fan isnt turning on, heard it could be the ECU?, electric winndows arnt working ??, the insides getting really hot and smells like exhaust fumes? has no heater/aircon so couldnt be that, and have been told by the RAA that it has a dash problem?
    anny help with this would be great cheers
    Ford Xe
    Dec 2006
    Reaper's Avatar
    Reaper is offline Tells it like it is.
    E3 Senator Manual, VP SS
    Aug 2004
    sounds like you have bought a fail of a car. Sell it for whatever you can get and buy something that isn't fubar.
    Reaper
    Reapers Black VP SS
    0-60 mph = 5.39 Sec, 2.30 60'
    Quote Originally Posted by skruba View Post
    practice makes perfect dude i was (still am) my bros guinea pig,he has been tattooing for near 2 years.
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    sounds like it might have seen better days, there's a thread in the howto about how to make the fan come on with a switch, try that. could also be worth temporarily running a 12v direct to it to see if power to it makes it go, otherwise it could just be a fried motor.
    the cabin/heat are you sure it's got no heat? didn't think you could roady without that. if the heater tap goes you'll get heat whether you want it or not, so that could be it, but if it's heat and stink i'd be looking at cabin seals. check under the gearshift boot. but for fumes to be making it from the rear exhaust to their is hard to believe, so you could have an exhaust leak closer to the front.
    also if it's a vn calais then it's live axle, and you can't have it set up for camber, which is an IRS term.
LinkBacks (?)
  1. 26-03-2011, 04:35 PM
  1. Car Troubles
    By raiden_6969 in forum General
    Last Post: 20-12-2009, 04:54 PM
  2. Calais Power Steering Troubles?!?!
    By Troyziee in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-05-2009, 11:11 AM
  3. v6 troubles
    By VTPREDATOR in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-05-2008, 01:01 PM
  4. vn troubles
    By VNSV in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-07-2005, 01:43 AM
  5. Vt Troubles
    By da_doc in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-06-2005, 11:36 AM
