Hi all, My VP Aircon is dumping water inside the cab, Its probably a blocked drainage hose but I am struggling to locate the hose - Can anyone help with a pic or instructions
They are just above the transmission up inside the trans tunnel. If you look carefully you will see the drainholes in the floorpan.Theres one either side.Dont stick anything hard like a screwdriver up in them to clean them,you can damage the heater core or A/C evaporator.Use something long and fairly soft like a piece of copper wire.
