Results 1 to 21 of 21
Thread: T700 won't give fourth until 100+kph :(
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Question T700 won't give fourth until 100+kph :(
    Factory auto in a 304 VN won't give me fourth gear properly.. as of this week. It was fine before.
    • Fluid level seems ok, if anything a little on the high side
    • There's a large transmission cooler in the system, inline after factory in-tank one
    • The auto has only just recently been serviced (a week or so ago)
    • TCC lockup never works in this auto
    Not sure if those things have anything to do with it but that's all the relevant info I can think of.
    could this be kickdown related?? all the other gears shift at the right time and I haven't reset the cable all that recently (did it a few weeks ago, worked fine for a while then fourth has gone all retarded on me later on down the track)
    anyone got any ideas please let me know.
    sam
    WTB: mulberry VN interior parts
    92 VP Series 2
    Jan 2009
    East Brisbane
    hey mate, even a bit overfilled tranny oil in these transmissions can cause problems, better to be a touch under the full mark then over it. how over is it? if its only a little bit just undo your speed sensor on the side of the back of the transmission to drain a little bit out
    92 VP Series 2
    Jan 2009
    East Brisbane
    p.s. if that doesnt work and you run out of ideas and are thinking about getting a new transmission, first go to super cheap auto and grab some stuff called lucas transmisison fix. alot of people dont like additives, but about a year or so ago i had similar problems with my auto and it wouldnt lockup the torque converter, but after a few days of adding this stuff it was running a hell of alot better. the main reason people dont like using these so called "snake oils" is most of the time its either make or break. some people will have good results and some people wont. alot of people say that is just a band-aid rather than fixing the problem, but after a year mine is still going strong...... of course its your gamble to make....
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    +1 sticking valve in the valve body (rebuild)
    OR
    +1 new tourque converter itself (they do flog out but normally theyshow other driveing issues aswell like hunting for a gear at about 115km/hr
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    cheers guys, I have a T5 conversion in mind anyway for this car so this is one of those fix-if-it's-simple things...
    update: took her to 130kph tonight and finally engaged fourth.. from then on fourth was engaging in its proper time - about 65kph. Not sure if that sheds any light on the issue?
    S/C VN, VY SS, Waverunner GP1200
    Dec 2005
    S.A
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    yep and it's greenfoam massaged for my preference to lock up at 65kph..
    doesn't.
    didn't work on the factory auto memcal either, where it should have locked up at 90ish.
    not a big issue (looking at T5 conversion) but i'll fix it if it's simple.
    D3V14NT's Avatar
    D3V14NT is offline Likes Shiny Things
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    Maybe a problem with the lockup solenoid or associated wiring?
    If you take the pan off its at the front of the trans at the oil pump. 2004R 700R4 700 4L60E 4L65E NEW LOCK-UP SOLENOID KIT - eBay (item 260118926628 end time Dec-26-10 13:57:53 PST)
    1. 1990 VN Exec V6
    2. 1993 VP BT1 3.8L - Now wrecking for parts!
    3. 1991 VP Berlina V8 - RIP
    Looking for a good condition VN - VS V8!!!
    Dec 2005
    S.A
    If you're keen, here's the diagnostic for TCC from a factory VN manual.
    Attached Thumbnails Attached Thumbnails T700 won't give fourth until 100+kph :(-tcc-pg2.jpg   T700 won't give fourth until 100+kph :(-tcc-pg1.jpg
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    if it came good for a bit after engaging my bet would be either debri stuck in one of the valve assembely
    or a stick main solenoid
    either way rebuild the valve assembly or replace
    VN WAGON
    Sep 2007
    it will be a valve, ive had the same prob. and convertor would be playing up. its usualy the 2
    D3V14NT's Avatar
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    Time for a stage 2/3 shift kit and chuck in a new solenoid haha
    1. 1990 VN Exec V6
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    nope. not ever rebuilding another auto.
    ever.
    T5 instead, no question
    92 VP Series 2
    Jan 2009
    East Brisbane
    any chance do you have an oil leak coming from around the back of your transmission? if so you may need to change your speed sensor o-ring which will keep a bit of extra pressure in your tranny and may help with the torque convertor lockup. retails for something like 20 bucks from holden......
  15. #15
    D3V14NT's Avatar
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    Bad experience with an auto rebuild? I've got a rebuild kit coming from the states and my trans is already in pieces. Doesn't seem like it's too hard of a job, I've already fitted everything from my stage 2 shift kit without much hassles.
    As zskinner mentioned check out your trans for any oil leaks, seals and o-rings are usually pretty cheap n easy to replace. If there's no leaks, everything is connected properly and the fluid levels are back down to to the right level then I'd be getting your T5 as there is not much else you can do without opening it up.
    1. 1990 VN Exec V6
  16. #16
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Quote Originally Posted by D3V14NT View Post
    no bad experiences.. just expensive and i hate autos anyway
  17. #17
    vr v6
    Aug 2009
    I,ve rebuilt my auto ,it was bloody hard.The main problem i had was lack of proper tools. Also when i bought my rebuild kit and shift kit i got told to rebuild the auto and then put the shift kit in after, problem was the shift kit had all new spings for the clutch spring assemblys.
  18. #18
    D3V14NT's Avatar
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    Quote Originally Posted by savage1987 View Post
    Fair enough I guess, I'd rather a manual too to be honest. But for the price I'm spending on the trans it's either a case of rebuild this auto so that I know it'll be solid or go and grab a manual from somewhere to do a conversion and hope its still good. Managed to pick up the rebuild kit, stage 2 shift kit + a heap of other goodies for under $500 so can't complain. If I was paying aussie prices for it all I would've done the manual conversion haha.
    Quote Originally Posted by Guzzoline addict View Post
    That'd suck, fortunately I haven't made that mistake. So far I've pulled it all apart and put in everything from the shift kit, just waiting on the rebuild kit to arrive so that I can put the stuff from that in an re-assemble it. The only thing that has me a bit worried is how I'm going to compress the input spring retainer enough to fit the snap ring back on. The new springs from the shift kit are rock solid haha. Might have to make something up to do it or see if I can hunt down a g clamp big enough to get down into it
    1. 1990 VN Exec V6
  19. #19
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    I've been wondering just out of curiousity for a while now.. how hard is it to rebuild an automatic? I've done most of the rest of a VN but never the auto.. is it just a case of a few specialist tools and careful methodical work? Or is there more to it?
  20. #20
    D3V14NT's Avatar
    93 VP BT1 V6
    May 2009
    Geelong, Vic
    It's a pretty easy job, particularly if you're mechanically minded. There are a few speciality tools for the job that make it a lot easier to put certain parts back together but if you're creative there are other ways and tools that do the job.
    It's mostly a case of dismantly it carefully, making sure you note the order of the parts in which it was dismantled. Clean the parts you are keeping and then re-assemble it using the original parts you are keeping + the parts from the rebuild kit. For all the complexity of an auto trans, pulling one down and rebuilding it is pretty straightforward if you pay attention to what your doing.
    There isn't actually much to a rebuild, new seals, bushings, clutches, steels and a band. If you want a more solid and reliable box you can get updated parts to put in there while you're doing the rebuild (steel pistons, 'beast' sun shell, updated planetary gear, 13 vane oil pump kit, shift kits, corvette servo, blah blah). If you have a look at that ebay shop I linked to earlier and go through the 700R4 category you should get a fair idea of what makes up a rebuild kit and what parts can be updated along with it. If you get a transgo shift kit the installation video on transgo's website is invaluable for your first time installing one and also shows you how to make sure the band is sitting correctly . There are also a couple of good youtube videos on how to pull down the trans.
    When the rest of my parts turn up to finish the box off I can take a few photos of the rebuild process for you to have a look at if you'd like.
    1. 1990 VN Exec V6
  21. #21
    savage1987's Avatar
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    Thanks! I will attempt this one day just for the learning experience.
  1. [WA] WTB: VN t700
    By Panama in forum Swap / Wanted to Buy / Trade
    Last Post: 19-02-2009, 10:55 AM
  2. Auto not changing to fourth
    By VRFURY in forum VL Holden Commodore (1986 - 1988)
    Last Post: 19-04-2006, 09:31 PM
  3. auto trans starts in second gear,no upshift to fourth
    By driver in forum VL Holden Commodore (1986 - 1988)
    Last Post: 10-11-2005, 07:04 AM
