Results 1 to 16 of 16
Thread: Car maintenance....what should i do next????????
    vp series 2 1993
    Oct 2010
    Default Car maintenance....what should i do next????????
    Hi guys,
    I am currently doing some maintenance on my car and was wondering what the next move might be? i have a 1993 vp wagon series 2 witch has done just under 350,000 ks. Generally it runs ok apart from some roughness when its hot weather with the air con running. These are the things that i have done so far......
    late last year - new crank angle sensor ( old one stopped working )
    last week - new leads, plugs, oil, oil filter, air filter
    tomorrow - im going to clean/ flush the cooling system with new thermostat
    wednesday - booked in for new fuel pump and filter
    im hoping the cooling flush and fuel pump will help make the car run smoother but i do realise that there is only so much i can do to improve a 17 year commodore. i might get the water pump checked over aswell but would like to know what else i should do to help keep the car running well......thanks in advance for your feedback!
    Vr ss & vy v6 wagon
    Jan 2010
    Central Coast, NSW
    D22 St-r Navara
    Dec 2010
    perth
    the roughness from the aircond running might mean the aircond clutch pully is on its way out. flush the gearbox out with a new filter also, check uni joints and suspension rubbers, more so the front strut links and rear upper arms
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    Check your brakes and discs, how old is the fluid?
    Transmission flush.
    Illegitimi Non Carborundum
    vp series 2 1993
    Oct 2010
    thanks for the replies.........brake fluid is ok but i will check the tranny fluid and see how that is. Didnt think of the throttle body but i will check that also, im fairly sure the throttle body was cleaned maybe 16-18 months ago
    92 VP Series 2
    Jan 2009
    East Brisbane
    get a new coolant temperature sensor (about 15-20 bucks from holden). very very easy to install, do it while your doing your coolant flush cos otherwise you may lose a little bit of coolant (but even if youve already done your coolant flush still do it, you will only lose a very little bit of coolant if you unscrew the old one out really quick and screw in the new one really quick). also do your oxygen sensor (around about 60-70 bucks from repco or ebay) if it hasnt been done in the past 50,000 kms. both of these sensors will gradually start to die and can have a very large effect on fuel economy. i can ALMOST guarantee that if you havnt changed either of these sensors in the last 50,000 kms that changing them will make a noticeable difference to fuel economy. also wouldnt hurt running some injector cleaner through your fuel system. and if you have some money saved up and wanna go all out, grab some ultrasonically cleaned fuel injectors for like $100 off ebay and throw them in
    vp series 2 1993
    Oct 2010
    just an update....i fushed the cooling system on monday using the method written in the how-to section ( flushing a v6 cooling system ) which worked great!, i took the car to mechanics today and on the way the car became rough and almost cut out, leaving me with no accelaration. at the time i had both air con and fan on, after turing both off it seemed ok but happened again once i turned both on again. the mechanic installed fuel pump with filter, serviced the air con and replaced the brushes on the rear shockers. the car still has a miss somewhere which is frustrating and i'm worried it may run rough and cut out again.....any ideas of what i could checked first as i am fast running out of money with both christmas and a holiday coming up????????? all replies are much appreciated!
    92 VP Series 2
    Jan 2009
    East Brisbane
    if you've done your leads and plugs, the next most probable things to cause a miss are your coil packs or the ignition module. you can get them in a pack altogether from ebay for a couple hundred bucks
    92 VP Series 2
    Jan 2009
    East Brisbane
    perhaps even a blockage in your exhaust somewhere can cause missing/hesitation/stalling too......
    VR Commodore, VK EFI 5.0 Calais
    Nov 2010
    Mount Gambier
    in regards to basic maintainence, what ya haven't mentioned is the diff oil or the belt, when doing the belt you can check all your pulleys, the idlers are pretty common for wear
    vp series 2 1993
    Oct 2010
    hey guys, thanks for everyones help so far its been very helpful. Today i got my hands on a ignition module/coil pack and put that on but it doesn,t seem to have help with the miss, i also put some injector cleaner in before i filled up with fuel tonight. i'm now pretty much out of cash till after christmas so im hoping the car can stay in good shape till then.. if there is any other cheap things that can be done plz let me know, i'm also gonna look into the other suggestions people have made on here.. thanks again guys!!!
    VP Commodore wagon v6
    Jun 2010
    Moe, Victoria
    Quote Originally Posted by zskinner View Post
    mate, where on earth can you get them for 60-70? I went to the local repco the other day and they wanted $115!
    haven't been working for over 10 months and I HATE IT. If you know of any positions, let me know please, I'm willing to travel/move if necessary. I just want to be working again!!!
    '94 VR Exec
    Feb 2010
    Wagga Wagga, NSW
    Even a can of upper engine cleaner from a Subaru dealer wouldn't be a bad idea, my VR was noticeably smoother afterwards. Cost about $20 per can though.
    92 VP Series 2
    Jan 2009
    East Brisbane
    Quote Originally Posted by psshhhht View Post
    my bad, just double-checked the ebay listing i got the price from and it was only for the vn 1-wire, not the vp 2-wire
  15. #15
    Vp Calais charged v6
    Oct 2010
    Melb Vic
    Hey mate, with regard to it running rough, with that Amount of m's it's not uncommon for them to run rough, could be a lifter not pumping up 100% or even the valves in the cylinder head not sealing 100% either, worst case scenario. Cheers
  16. #16
    ConMan_VP's Avatar
    ConMan_VP is offline P Plater
    1992 VP Commodore Ute
    Sep 2010
    Southern Tasmania. Ex Adelaide Boy
    a trans oil change and new filter, pull the sump off the trans, oil every where, pull the filter off, put a new one in, sump back on and then new oil.
    If all else fails HIT IT WITH A HAMMER !
    Country Ute.
  1. Confused about LPG Maintenance ?
    By Ron41 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 09-05-2007, 08:40 PM
  2. VR/VS Maintenance Guide
    By RhysVR in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-11-2006, 07:41 AM
  3. VY II Maintenance Qs
    By Puggle in forum VY Holden Commodore (2002 - 2004)
    Last Post: 24-06-2006, 05:20 PM
  4. Maintenance
    By harveyt in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 15-03-2006, 07:06 PM
  5. Car Maintenance
    By tr3nt in forum The Pub
    Last Post: 10-08-2004, 08:08 PM
