Results 1 to 21 of 21
Thread: Vn ss knock then shudder when acclerating from 80 pls help
    vn ss
    Dec 2010
    wa
    Default Vn ss knock then shudder when acclerating from 80 pls help
    hi guys just bought this car... when cruzing at about 80 then accelerating to about 3thou revs there is a knock then a shudder. took it to a mechanic and he put it on the computer and could not find any faults. maybe transmission? any help would be appreciated its an auto vn ss
    Dec 2009
    It's not a miss under load? Take off your spark plug leads and check their resistance.
    vn ss
    Dec 2010
    wa
    hey man thanks for the reply... happens even when going down an incline though . may be torque converter after reading about an hours worth of threads last night
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    check if driveshaft bolts are loose
    check trans mount ok not sagged or loose
    check engine mounts not split or loose
    check diff backlash ok (would do in other gears normally but)
    check auto oil level ok and clean
    if none of above do an auto service before replacing the box or getting diff checked by a professional
    vn ss
    Dec 2010
    wa
    thanks m8 had a quick look at all bolts and mounts seems fine, oil level is fine and like new clean.how much is a service usally and i pressumed the converter is its own part/ no .........spoke to a transmission guy yesterday and he said if its the converter it should be round 900...
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    does the knock sound like its under you or behind you or infront of you?
    exactly when noise occurs
    eg driving staying at 90 then flat to floor accelerator and it knocks as gear changes
    a service is cheap but oil is costly this is a last resort before replacing trans though!~
    vn ss
    Dec 2010
    wa
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    then safe to assume its gearbox related
    first i would check mounts VERY WELL if they are split or sagged the motor will twist the box and it hits the floor pan
    often mistaken for internal gearbox fault
    so
    when the knock happens does the whole car shake like its affecting acceleration? or is it just a sound? EDI|T soz re-read title
    a shudder means its a problem with the supply of power to the rear wheels
    my gueass at that speed would be converter or low pressure of the fluid inside the box
    either way i would "recomend" having the car driven by the gearbox mechanic so he can feel the fault occur
    his knowledge and on hand feeling the fault happen will help him make an educated decision on wether or not its inside box or converter
    he will MANUALLY go through the gears and try to make fault occur and also in DRIVE make fault occur
    then he SHOULD be able to tell wether or not to rebuild the box or just put a new converter in
    if it is converter when its cruising it would be in its highest gear when you accelerate there would be a longer than normal delay then it would drop down a gear
    this is caused by the converter getting stuck this
    is also common fault..
    let us know how you go!~
    basically i can give you more checks to do but without feeling the fault myself i might lead you the wrong way and we
    would both end up very frustrated
    vn ss
    Dec 2010
    wa
    somtimes its a faint knock then a shudder other times its hard knock doesnt happen any other time going through gears even up to 100 only happens when ur cruzing at 80-100 then acclerate
    vn ss
    Dec 2010
    wa
    yeah.. its affecting accleration for the period of the shudder then stops once its into gear
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    Quote Originally Posted by sootty grunter View Post
    this would lean me towards the converter~! or the switching of the converter (oil pressure in box)
    as it would be in top gear 1 is to 1 ratio or converter locked into place providing drive directly to the wheels from the motor (basically )
    vn ss
    Dec 2010
    wa
    nah no point gettin frustrated! think the trans mans the best go thanks heaps for all your advice will let you know how i go not that mech minded so might get him to check mounts ect thanks again
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    yeah too easy pm me when you know what fault is
    im one of "those" mechanics that has to know the end result
  15. #15
    vn ss
    Dec 2010
    wa
    Dec 2009
    The other thing you could check is the transmission cross member, not sure about a V8 but on a V6 auto they are in two parts, there's a small one bolted to the rear transmission mount then this bolts to a bigger one that then bolts to the car. I had a knocking in my VN and the rubber gearbox mount bolts to the cross member were loose, you couldn't see them from under the car without taking the larger part of the cross member off first.
  17. #17
    vn ss
    Dec 2010
    wa
    Hey guys took the car to a transmission bloke today,as always the problem did not occur as bad as it has been , but did occur slightly ,as advised buy db_not so.(your onto it) .he advised me of a service and a tube of something to prevent the converter from sticking cost roughly $180 all up booked in next tues.we'll see how that goes otherwise he'll have to pull out the box but service will not be wasted for future problem havers......will let u all know how it goes.
  18. #18
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
  19. #19
    vn ss
    Dec 2010
    wa
    hey guys nah spewing no luck with the service etc..must be the converter have to save some coin and sort it out... want her running sweet ... also found a matching transmission/converter whilst working is this of any use?..thanks
  20. #20
    VP Berlina LX
    Jul 2010
    i have a the same thing happen in my v6 auto sometimes...
    If after installing your new stereo all you can hear is rattling, you need a louder stereo.
  21. #21
    MasterOfReality's Avatar
    MasterOfReality is offline Thats Dr to you.....
    VP HSV Enhanced Calais, 2006 Suzuki Grand Vitara
    Feb 2004
    Where the mines are
    Have you checked your plugs and leads yet?
    I had this exact same problem, it honestly felt like the box was about to fall apart.
    It was just a misfire - a new set of lead and problem solved.
  1. knock knock......whats there?
    By xitekamelion in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 19-09-2009, 12:43 AM
  2. Shudder
    By jyothi in forum VY Holden Commodore (2002 - 2004)
    Last Post: 12-06-2009, 05:19 PM
  3. Shudder
    By hazza in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-03-2009, 06:06 AM
  4. knock knock, whos there?
    By blunt in forum Jokes/Humour
    Last Post: 03-11-2005, 06:03 PM
  5. knock knock bloody knock
    By petesvns in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 12-03-2005, 12:39 PM
