Results 1 to 6 of 6
Thread: 304 vs LS1 for Street/Track buildup
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Default 304 vs LS1 for Street/Track buildup
    My dad and I are looking at building up a street/track car.
    We're planning on using a VN or VP for the build (Probably going to choose the VP because we prefer it in the looks department), and am curious as to which motor to choose.
    Either way, the motor WILL be worked. We're looking at running about 500hp or so (Well, hoping anyway), and aren't really sure which motor to go.
    I know that the LS1 is more capable but that requires the conversion, and I'm not entirely sure how difficult the conversion is.
    On the other hand, the 304 is a proven strong motor as well, and doesn't require engineering.
    BUT, the LS1 will bolt up much better to a T56 which is stronger, and we'd prefer a 6-speed as well.
    So, we're kinda leaning towards a conversion, but would just like other peoples opinions.
    Thanks.
    Quote Originally Posted by PaRaDoX View Post
    btw do you plan to fly? looks like you have a gauge for everything, refreshment levels gauge, washer fluid temp? penis pump vacuum? *runs and hides*
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Why is "power" so important? Do you have a little dick?
    People are too obsessed with how much "power" their car makes....it doesn't make power, it produces torque, from which this mythical "power" figure is calculated.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    It will depend on how much money you want to throw at it. If you want to keep it licensed, then engineering is necessary, but a dedicated track car doesn't need all that. If you get a V6 starter car, then it will need inspecting anyway to put a V8 into it.
    Personally I would go the LS1, more work to get it in, but less to achieve 500 ponies.....but then torque is what you seek.....
    Visit my Facebook page
    VR Commodore V6
    Sep 2008
    Sydney NSW
    I understand it will need to be engineered. That's not a problem, I'm willing to do it anyway. I want it to be a perfectly legal street car as well. Just more suited to the track, if you get what i mean?
    Money isn't a problem. Obviously, I'm not willing to spend 200k. But I know it's going to cost, but it will be a long term project. As I get more money, I'll start putting more things onto it, until finally it's all together ready to be blue-slipped, engineered and registered.
    As I thought with the LS1. What exactly would be involved in getting an LS1 with a T56 into a VP commodore body? Do I have to get things like engine and gearbox mounts custom made? Or is there already pre-fabricated ones to suit?
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    There are a couple of threads on LS1 conversions, here is one. Sam's VN Lexxxcen LS1 T56
    VR Commodore V6
    Sep 2008
    Sydney NSW
    Does all the stuff applying to a VN apply to a VP pretty much?
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    Pretty much as the vp had a light make over body and trim wise, along with a wider track.
  1. v6 buildup q's
    By TorquemonsteR in forum V6 Development And Modification
    Last Post: 20-04-2006, 02:20 AM
  2. carbon buildup
    By pingin in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 11-02-2006, 03:19 PM
  3. Vk Buildup
    By clinker42 in forum General
    Last Post: 28-09-2005, 10:59 PM
  4. Sludge Buildup
    By daggett in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-06-2005, 10:26 PM
  5. Sludge Buildup
    By ChRiDDa in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-03-2004, 10:30 AM
