Results 1 to 10 of 10
Thread: removed bellmouth=engine light on
    Ford Xe
    Dec 2006
    Default removed bellmouth=engine light on
    hey guys i removed my bellmouth and tryed resetting it without a rev tacho but just reved it constantly for 8 seconds. does it need to be exactly on 3000rpm?
    and now my engine light is on?
    help thanks
    soop is offline Banned
    2003 SS Commodore Series II
    Nov 2008
    Smithton, Tasmania.
    You've knocked something off the engine. Go make sure everything is plugged in properly.
    VP calais, VJ valiant, BG5 legacy
    Jan 2008
    New Plymouth, New Zealand
    Check all your plugs and vac hoses. Is it idling ok?
    And no, you dont need to rev it. It will learn the changes (if any) quick enough.
    Quote Originally Posted by QuickVRII95 View Post
    Elaborate, For All Of Us... How The Hell Is A Commodore A Friggin 4-Stroke...???
    Where Are You Getting Your Facts From...???
    You All ARE Wrong About A Commodore Being A 4 Stroke Engine... Or Any Car For A Matter Of Fact...
    A V6 CAN'T Run On ONLY 1 Cylinder... IT'S A 24 STROKE ENGINE... 4 CYCLES Per Cylinder... "Basically Three V-Twins Together
    Ford Xe
    Dec 2006
    oh k, well yeh starts fine and when cold, revs high then drops after 1 second , i thought it would rev higher when its cold for quite a while?
    92 VP Series 2
    Jan 2009
    East Brisbane
    do an error check bud. if engine light is on it should have stored an error code in your ecu, that should narrow the problem down a bit
    Verynice's Avatar
    Verynice is offline Band
    VS Caprice 5L
    Aug 2008
    SA - The Backwards State
    yeah mate as above check error codes, it basically tell you whats stuffed instead of you going looking for it
    WogBoyz's Avatar
    WogBoyz is offline Cammed & Eventualy Blown!
    08 VE SSV Ute
    Feb 2009
    Cairns, Qld
    Quote Originally Posted by NV-VN View Post
    i wouldnt be revn your car higher while its cold
    Now Saving for a Harrop HTV2300 Supercharger kit!
    Quote Originally Posted by skyracer View Post
    On new years eve I got stopped by a pack of about 5 people forming a road block. All of them naked. They proceeded to turkey slap my car as I rolled past...
    Ford Xe
    Dec 2006
    just checked all the connections, there all in, il have to do an error check on the ecu i have no idea whats the go
    D22 St-r Navara
    Dec 2010
    perth
    vs commodore
    Oct 2009
    Tamworth NSW
    Dont disconnect it,this will clear any set codes and you wont know what has caused the engine light to come on then,just follow the steps in this link to check the codes.
    ---Checking your Computer for Faults (VN - VP)---
    Once the codes have been flashed up and youve written them down or whatever,then you can disconnect the negative battery terminal which will then clear any set or old codes logged in the ECU.
  1. ENGINE light, ABS light, TRAC OFF light AIRBAG light and OIL light
    By jamierawr88 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 09-10-2011, 09:06 PM
  2. HELP Engine Light / Transmission light and rough gear changes
    By flash20005 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 13-10-2010, 03:34 PM
  3. Engine stops, fuel light on, battery light on GOODBYE
    By scarletx in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 23-06-2009, 03:43 PM
