Results 1 to 5 of 5
Thread: how much would you pay for a vp 5L sedan
    chooky1980's Avatar
    chooky1980 is offline Donating Member
    vh sl/e,vk berlina
    Nov 2010
    deniliquin
    Default how much would you pay for a vp 5L sedan
    hi all,theres a white vp 5L auto sedan at a dealership here and they want $1700 for it but i rekon i can get them lower.its white(paint needs work it's had panels resprayed with clear over base and the clears lifting),it's on gas,has front power windows and an old bloke owned it since new.it needs a general clean up.needs-centre bearing,ignition barrel,l/h headlight,brakes need work and it looks like the l/h radius rod might need replacing(crossmember has taken a bit of a hit where the tow hook is)and it has a few oil leaks.it's really straight though and won't take much to paint it.when i took it for a spin i drove it like it should be driven and it went pretty hard and runs good on gas.they rekon it's had work done to the heads but i'd say the work done was just for the gas.any ideas what price it's worth now and what it would be worth cleaned up and resprayed? i can't remember how many k's are on it or what badge it is.cheers
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    You probably wont get a VP 5.0L much cheaper than that anyway (working car that is)
    VP's are easy to fix up and parts are not to pricey for the Exec stuff.
    and 3 Dangerous non ABS VN's
    pjdm1980's Avatar
    Feb 2009
    Geelong, Victoria
    If it a exec then depending on condition anywhere up to $3500-$4000, and the more problems the less it's worth obviously.
    vp ss 5l
    May 2009
    western sydney nsw although that could change
    D22 St-r Navara
    Dec 2010
    perth
    depends on condition, mileage anyway between 4k to 12 k
  1. Replies: 0
    Last Post: 17-10-2010, 03:54 PM
  2. [NSW] WTB: Lowered Springs + Shocks To Suit HBD VZ Sedan On 19's and To Suit VK Sedan LA
    By VKCOMMO in forum Swap / Wanted to Buy / Trade
    Last Post: 08-09-2010, 09:34 PM
  3. [SA] MONROE GT Gas VB-VS SEDAN LOWERED REAR SHOC COMMODORE SEDAN (new)
    By mag in forum Parts And Other Items For Sale
    Last Post: 16-05-2010, 09:06 PM
  4. Will VN Sedan Rear Shockers / FE2 Springs fit into a VH Sedan?
    By VHSLX3300 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-01-2007, 12:28 AM
  5. 253 RED in 84' VK Sedan?
    By broderikb in forum V8 Development and Modification
    Last Post: 12-12-2006, 09:42 PM
