Results 1 to 10 of 10
Thread: LPG Removal from 5 Litre VQ
    Snitz92 is offline LPG Sucks.
    '99 Subaru WRX, '89 Nissan 300ZX V6TT Targa
    Apr 2009
    Ceduna
    Default LPG Removal from 5 Litre VQ
    Hi, my VQ Statesman has LPG, which I would like to remove or get removed. Does anybody know of a LPG Specialist around Adelaide, or a mechanic or business who could professionally remove my entire LPG System? It's barely any better for fuel costs, so why have it? And the power loss is extremely high. Please help. Any help will be very muchly appreciated. :-)
    GTP 85's Avatar
    GTP 85 is offline 291 hp @ the wheels
    VS track car & VS SSenator
    Aug 2006
    Adelaide, near the bay
    you can do it yourself, i did. every LPG tank has an emergency cut off valve on the tank itself so there should be no problem with gas escaping if you do it properly. the ones i had were cut of by a screw tap, shut it off and all the lines can be removed. when u release the line u will just get a short hiss which is just the residual gas in the line
    I'd also suggest to disconnect all the spliced in lpg wiring too, as it caused problems for me recently... 8 months down the track
    Hit me up with some reputation points if i've helped you out! (Star in the bottom left!) Cheers!
    GT Performance RUF 231- NA 3.8L- 13.30 @ 103 Mph... So far... Cam, compression and revs! MY CAR>> http://forums.justcommodores.com.au/...tml#post471410
    Daily VR SS: http://forums.justcommodores.com.au/...ite-vr-ss.html
    LS1 VT SS
    Sep 2004
    Mandurah WA
    I dont suggest doing it yourself at all, The lpg shut off valve is only from the tank to the mixer not from the filler point to the tank (at least on my duel fuel vn v6.) so if you were to undo the filler line to the tank the gas thats i the tank will escape, Depending on how much gas in the tank it could quite easily turn into a bomb.
    1999 LS1 VT SS
    1991 VN V6 T5 Commodore
    Blown V6 Hatch's Avatar
    Blown V6 Hatch is offline Too many projects.....
    VN Calais 5.0, UC Torana hatch 383, WB Ute 5.0
    Jun 2005
    Cowes, Phillip Island
    Quote Originally Posted by Alloytec View Post
    No it wont, the filler line has an internal 1 way valve.
    2007 SVZ Wagon
    Aug 2007
    Murray Bridge
    Regardless of what 'the experts' have to say, I suggest that you consult with an Auto LPG INstaller - any installer. The potential for things to go wrong is just too great. Check the Yellow Pages or try Google. There's hepas of such installers in and around Adelaide.
    LS1 VT SS
    Sep 2004
    Mandurah WA
    Actually yes you will as you will have to remove that filler line to take the tank out. The one way valve is the LPG connection itself that you screw the hose on to fill it up with.
    1999 LS1 VT SS
    Jun 2005
    Well, I've removed heaps of gas tanks for re-test and no gas has ever come out of the filler line. Also, I've watched the guy re-test 1 on site and they have a 1 way valve on the filler line (inside the tank)...
    GTP 85's Avatar
    Aug 2006
    Same here. i've done about 5 cars...
    Apr 2009
    Ceduna
    Ok, all sounds well and good but I can assure you I am not doing it myself. Not confident enough to stuff around with LPG. No particular workshops in mind with decent labour rates?
    Apr 2009
    Ceduna
    Ok, I was just quoted $150-200 for labour to get the LPG components removed and engine re-timed and whatnot.
  1. VE SV6 head unit removal and head uni fascia removal
    By IGNITIONSV6 in forum VE Holden Commodore (2006 - ?)
    Last Post: 08-04-2011, 05:45 PM
  2. HSV VT 5 Litre vs Standard 5 Litre
    By Oken in forum General Discussion
    Last Post: 03-08-2009, 06:56 PM
  3. 6 litre or 5.7 litre conversion
    By kohan in forum LSx Development and Modification
    Last Post: 28-06-2009, 01:43 PM
  4. v6 to 5.0 litre
    By reggie_c2005 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-04-2007, 05:18 PM
  5. when it comes to a 5 litre
    By commod8 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-04-2006, 09:34 PM
Tags for this Thread
