Results 1 to 9 of 9
Thread: VN Series 2 No start
    LS1 VT SS
    Sep 2004
    Mandurah WA
    Default VN Series 2 No start
    Hey guys ive had this problem with my car that i've been trying to chase for a while now and its starting to get the better of me. If anyone could shed some light on what may be my problem i be much appreciative.
    Car in question is a 1991 vn s2 auto running on duel fuel. I have had the engine + gearbox out to replace transmission a little while ago, It ran after this but was breaking down when you put it under load either free reving or when driving, worse when driving. I tried swapping DFI/Coilpacks with another that came off a running engine (a vp i stripped for parts) and since then it hasnt started since even with the original coilpacks/dfi that were working previously. I removed the whole wiring harness from ecu to engine and check it for broken wires/continuity and it was all fine. I then cleaned every connector on the harness and reinstalled it to the vehicle, now my fuel pump wont prime up (suspect faulty pump as i installed a s/h one when the original one died) but even on gas (lpg) the car will turn over fine but only cough and splutter and not actually run and idle. I've checked all my fuses/relays in the engine bay and they all appear to be fine, even tried swapping some of the relays around to no luck either.
    So were do I go from here ? can anyone offer any advice/help ? I really want to drive this car again, its been fair too long since I have.
    Thanks, Craig.
    1999 LS1 VT SS
    1991 VN V6 T5 Commodore
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    did you plug the engine loom back into the dash loom under the dash
    LS1 VT SS
    Sep 2004
    Mandurah WA
    Quote Originally Posted by delcowizzid View Post
    LOL, I sure did. How can i determine if its a problem with the CAS - DFI Module or Coilpacks ?
    1999 LS1 VT SS
    LS1 VT SS
    Sep 2004
    Mandurah WA
    When I said the whole harness I only mean the one that goes from ECU and runs to the engine sensors and plugs into those 2 big plugs by the battery/fuse box area. Sorry for any confusion
    1999 LS1 VT SS
    D22 St-r Navara
    Dec 2010
    perth
    make sure you plugged in the connector for the factory imobilser if it has one
    LS1 VT SS
    Sep 2004
    Mandurah WA
    it only has an aftermarket one and thats all working fine.
    1999 LS1 VT SS
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    I know the cas's are a common problem on old engines...
    2 things i will suggest...........
    1. make sure ALL earths are connected... I didnt connect one once and the car ran like complete shit... found it, fixed it and it ran perfect
    2. if above are all fine, usually if you pour water over your cas (if its on its way out) you should be able to start the car again.....
    These are things that have happened with my car, cant garentee its the problem with yours gl mate
    LS1 VT SS
    Sep 2004
    Mandurah WA
    Thanks for the suggestions but is there a better way then pouring water over the CAS ?
    How can i determine if the fault is within the CAS or the DFI/Coilpacks ? can i test them with a multimeter?
    1999 LS1 VT SS
    savage1987's Avatar
    savage1987 is offline fail champion
    LS1 VN + 304 VN
    Blackjack Champion!
    May 2005
    pouring water over CAS cools it down, it won't diagnose anything if you just pour water on it when it won't start anyway
    how does your fuel pump sound?
    WTB: mulberry VN interior parts
  1. vr series 2 start month
    By moff_man in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 14-02-2010, 09:17 AM
  2. VR series 2 wont start
    By im blonde? in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-08-2009, 11:26 PM
  3. Series II VN, just will not start.
    By 1vngal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-08-2006, 05:10 PM
  4. When exactly did series 2 VS start??
    By frenzal_tom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-10-2005, 05:00 PM
  5. Series 1 Vn - Won't Start
    By mephisto in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-10-2004, 10:23 PM
