hey everyone, need help desperately!!! just finished swapping all the running gear outa my VN 5ltr berlina, into my VR SS mock up body, got everything connected (i thought) engine turns over but fuel pump iz not getting power to it, and cant find where there wires from the VN's gearbox go to under the centre console in the VR, all other plugs where the same except this one, ANY HELP WOULD BE GREATLY APPRECIATED
check round the forums man there are wiring diagrams I've found helpful
cheerz brah
dunno about the vr, but the vs v8 loom i used had the speedo and reverse bits on the loom itlself, not through the trans tunnel like it was on my vp v6
vr/vs anti theft unit???
did you use a vr loom or vn loom?
if its a vn engine and u ran a a vr loom, the wires on the distributor need to be re arranged, also you need to reset the timing and have it spot on
cheerz, but i used the vn loom connected up the same cept 4 the gearbox wires
