Years ago i changed my swaybar link kit from standard back to the old vb-vl style short ones as i was told on here they were better.Anyway gotta change the swaybar link kit on me VP can anyone tell me the Nolarthene part number for the older model kit as i think it was alot better and lasted alot longer than the standard ones for the VN-VP. cheers and thanks MERRY XMAS! TO ALL
the early kits actualy loose stiffness on a later sway bar, personaly your better staying with the original type, just go a heavy duty.
The older VB style link pins will dramatically reduce the effectiveness of the sway bar, your better off with a Nolathane one, there's a new type out now that has a ball joint at each end and bolts straight in they are not cheap though but are your best option folowed by the Nolathane ones with the bent rod.
From the ones I have seen the Nolathane brand has the best shaped "rubbers"
