i have just completed installing factory cruise control from a vn calais into a vn s pack, but it doesnt seem to work, i have conected everything the same way as i removed it. i have run the diagnostic that is on this forum, and it worked, the light came on and the throttle increased 20% as it states, but when driving nothing happens. i have also tested all the wires for continuity and there is no breaks in the circuit that i can find.
can anyone please shed some light on what could be wrong? thanks in advance.
just what comes to mind..... have you installed the brake switch and/or clutch switch properly. maybe its stuck thinking you have the brake/clutch in because its not installed correct or something.... just my thought mate, good luck![]()
nah the switches work, i have even tried pushing in the switch by hand while driving to see if it would work but still no go, and i dont think the test would work if the switches didnt.... grrr its driving me nuts :S
You could have a faulty stepper motor (main black box thing)
Most times it's the brake switch not working correctly. How did you test the brake switch?
and 3 Dangerous non ABS VN's
