Results 1 to 20 of 20
Thread: Code 22 wtf!!!!!
    Ford Xe
    Dec 2006
    Default Code 22 wtf!!!!!
    hey guys, before i start id like to thank you's for the online support its been great
    i did a ecu check came up with code 22, baught a new sensor, then did ecu test came up with 12 so all good, i start the car, engine light comes back on (code 22) so i changed the plug.. start the car, engine light comes back on (code 22) as i did each step i reset the ecu
    so whats the go now?
    cheers
    vs commodore
    Oct 2009
    Tamworth NSW
    Check the wiring and connectors that go from the TPS - Throttle Position Sensor, through to the ECU.Unplug and then plug back in the wiring connectors a few times to make sure theres good contact in the connectors.Also check the wiring connectors at the ECU itself for corroded pins in the connectors.Also the TPS could be faulty.Ive also seen new cheap brand sensors cause problems like this,its best to buy genuine holden sensors instead of cheaper ones.
    Ford Xe
    Dec 2006
    im going to change ecu and see what happens. because the plug and sensor are getting contact. its shitting me now just spent 40 bux and isnt the sensor
    db_notso's Avatar
    db_notso is offline diagnostic technician...
    vt v6, mods(susp brakesetc...)
    Oct 2010
    sunshine coast, qld
    clear code again!~
    take battery negative off for ten minutes
    remove sensor and plug it in (loose)
    reconnect battery
    start car and see if codes still sets (dont touch accelorator)
    if it does NOT RESET the code: tps installed incorrectly
    if it does and sensor okay.......
    just to double check this is in a vn v6 v8 etc... (sounds stupid but the diagnosis is different and dont want to lead you down the garden path man)
    Ford Xe
    Dec 2006
    yep vn 6. theres no way of installing it incorrectly. its 2 screws with a washer and spring inbetween the throttle metal thingy and the sensor. or am i missing something?
    vs commodore
    Oct 2009
    Tamworth NSW
    The gregorys workshop manual for the VP V6 says-To install the TPS-With the throttle valve in the fully closed position,install the throttle position sensor onto the throttle shaft at a position 30 degrees clockwise past the throttle position sensor retaining screw holes in the throttle body.Align the holes in the throttle position sensor with those in the throttle body,install the screws and tighten securely.
    Id say the VN would be the same.
    vp ss 5l
    May 2009
    western sydney nsw although that could change
    Ford Xe
    Dec 2006
    hey brett i tryed putting it 30 degrees like you said, and when i started it car was revving very high(3000rpm) so mabey its different in the vn
    vs commodore
    Oct 2009
    Tamworth NSW
    Quote Originally Posted by Brett_jjj View Post
    Yeah,maybe it is different then,Ive also got a VN-VS V6 and V8 haynes manual it says:
    Disconnect the electrical connector from the TPS,remove the torx screws from the TPS and remove the TPS from the throttle body.
    When refitting the TPS,be sure to align the socket locating tangs on the TPS with the throttle body.Refitting is the reversal of the removal proceedure.
    Oddly enough,the instructions in it for the V8 says to turn it 30 degrees to locate it,then turn it back and screw it up though.
    The haynes manuals are pretty bodgey though compared to gregorys manauls.Even my VS V6 gregorys says to turn it 30 degrees etc,which I have done lots of times to put it back on ,and have had no problems.So I just dont know what the go is with the VN one,maybe someone here has a VN gregorys that says how to do it.
    Ford Xe
    Dec 2006
    sorry for the noob question brett.. but from which angle am i looking at the throttle body to turn it 30 degrees?
    i had the sensor on the top with the connection plug facing me? and to make sure, all thats in between is a washer and spring?
    vs commodore
    Oct 2009
    Tamworth NSW
    Its sort of hard to explain.You just put it together like you normally would, but you dont line up the screw holes when you push it on,you go a bit past them so they are just out of alignment with eachother(30 degrees),then once its pushed on,you turn the TPS back a bit, and then line up the screw holes and put the screws in.Also theres a small square adaptor block on the VS ones,it looks like the VP one is a bit different.The pic in the VP manual doesnt show anything between the TPS and the throttle body.The haynes manual says theres two washers and a spring between the TPS and the throttle body,but doesnt show them in the picture,pfff.Mate I hope that helps you a bit.
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    22 Throttle pos sensor below .2 volt for 2 seconds while engine running
    thats what i found... so if voltage too low could be loose connection in that circuit
    you would need to check if the "female" pins on the connector are opened up too wide
    or if the harness leading too that connector is pinched somewhere (around top lh motor?)
    that is if having sensor loose still sets code as above
    S/C VN, VY SS, Waverunner GP1200
    Dec 2005
    S.A
    I've found VN S1 throttle have no small adapter block while the later onwards VN S2 have one.
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
  15. #15
    delcowizzid's Avatar
    в∞ѕтεכ √&
    Jul 2008
    NZ
    the spring and washer should have a plastic adaptor on the outside of them if its fallen off you will get the tps code too
  16. #16
    Ford Xe
    Dec 2006
    ohh i havent heard that one before.. if this true for all vn tps? because that means i have to go wreckers (no licence) i called repco and autobarn and they dont know what im talking about with the plastic adaptor.
  17. #17
    в∞ѕтεכ √&
    Jul 2008
    NZ
    some TB's have then some the tps runs directly on the shaft as its a different size
  18. #18
    Ford Xe
    Dec 2006
    hmm sounds about right because the leaver of the throttle that sticks in the sensor, seems to be thinner than than the little lips inside the sensor to turn it. if you get what i mean, i might have to go wreckers and check a few different ones see if one has it
  19. #19
    db_notso's Avatar
    Oct 2010
    sunshine coast, qld
    yes then your missing the cap that sits on the shaft UNDER the tps
    explains why code sets when rev it....
  20. #20
    Ford Xe
    Dec 2006
    FIXED . thanks guys for all the help it was the cap over the shaft. when i went wreckers 4/5 vns didnt have the cover, but all i needed was the one =D im a happy man
  1. error code 12, 3 times then code 76
    By muzza in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 21-09-2010, 06:36 PM
  2. hi need some help code 68 & 75
    By fire6113 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2009, 04:45 PM
  3. 94 VR - Code 16
    By acex1138 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-10-2009, 09:38 AM
  4. Code 72 - Vehicle Speed Sensor (VSS) and Code 73 - Pressure Control Solenoid Current
    By VS Omega in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2009, 04:39 PM
  5. Code 14 what the hell is error code 14!@*&%#
    By Danzilla in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-05-2005, 12:35 PM
