hi my vn is making a winding noise its a simaller sound to a supercharger
im thinking it could be my aircon moter could i get a new belt for a vn with no aircon and bypass?im pritty sure its not my powersteering either any help would be much appreciated!
have you done any recent work on your car? particularly around the intake/throttle body? or has it just come up out of nowhere mate?
Id try removing the belt and then starting the car to see if the noise goes away.If it does,then its gonna be either the water pump,the AC compressor,the power steering pump,or the tensioner pulley bearing or alternator bearings.It wont hurt to start the engine and run it with no belt,but for no longer than 1 minute.Whilst the belt is off,and with the engine off,turn the pulleys etc by hand,feel for roughness and looseness in the bearings of the various belt driven components,if any roughness or loose or noisy bearings are found,its probably best to replace the complete part or just replace the faulty parts bearings if possible,like the tensioner pulley bearing,I paid $7 for a new bearing a few months ago at a bearing place.It was making a winding noise similar to what you have described.
zskinner na nothing mate its just getting louder
ok il give it ago ive recently replaced water pump and its made that noise before hand i havent had any problem with the powersteering pump allthough it does sound like it has no fluid in it
thanks bud!
Yes you can bypass it with a non AC type belt,I had trouble finding the non AC belt when I bypassed the AC compressor on my VS,in the end I ordered it through holden for around $30 .I ended up fitting a new compressor to get the AC working again for the summer.Same problem as you,the old compressor was as noisy as hell.
No worries.Cheers.
have you changed your idler pulley i had the same noise for 6 months then the pulley shit it self
