I have a 89 Vn manual series 1, i also have a recond series 2 auto... i would like to put the series 2 motor in but keep the series 1 manual box, i know ill have to get a series 2 manual flywheel but not sure what other issues i may have
thanks for any help
the cooling systems are different. the series one runs a high pressure set up. the series two a low pressure one. you will need a different coolant res and the radiator with a radiator cap also a different heater tap
i have both radiators, a series 1 and series 2. Im using everything from the series 2 besides the manual series 1 gearbox, thanks for ur help![]()
