Results 1 to 6 of 6
Thread: vp idle problems v6 need help asap
    vg ute v6 5 speed
    Jun 2008
    Default vp idle problems v6 need help asap
    i brought a vp v6 is 5 speed was auto but was changed before i got it.
    it idles really low without a tacho i'd guess 300-400rpm. will usually stall.
    drives well but may have a tiny little miss if at all.
    it was throwing engine light code 22 and 35
    35 being idle speed error and 22 being throttle position low voltage.
    but after two days fiddling it hasnt put either on
    i have replace throttle body twice off two different cars
    new plugs
    new leads
    new fuel filter and fresh fuel.
    new clutch as it was ####ed before i brought it.
    swapped map sensor with my manual ute
    tried different coil packs
    tried with and without air filter.
    took one injector off at time to eliminate one cylinder but all seem to be firing.
    i'm open to any suggestions or help will even leave my mobile i'm that desparate lol
    0406229188
    thanks justin
    accentstencil's Avatar
    WH II Caprice, 5.7
    Jun 2005
    Eschol Park, Sydney
    The IAC valve (Idle Air Control) controls the idle, so I would be checking that out.
    MY RIDE
    vg ute v6 5 speed
    Jun 2008
    thanks accentstencil but hey are on the throttle body that has had 3 swap overs so far also to update i just tried two different computers in it and a coolant temp sensor out of a running car
    any other ideas will try anthing
    92 VP Series 2
    Jan 2009
    East Brisbane
    hey mate, the computers you tried were they all from auto's by any chance? cos i believe you shouldnt have an ecu made for an auto in a manual car (you may need an ecu designed for a manual transmission), or maybe its the memcal im thinking of...... maybe someone can confirm whether its ecu or memcal...... or both......
    vk wagon
    Mar 2006
    gold coast
    VN VP ecus are the same auto or manual as auto controlled by kick down cable not electronic. Make sure there is no vacumm leaks, IAC is general prob usually clog up with carbon (can of carby cleaner will fix that)
    92 VP Series 2
    Jan 2009
    East Brisbane
    true true, must me memcals then, not ecu's. so have you tried using a memcal for a manual transmission mate? they're different cos autos have different settings particularly for idle which has alot to do with autos having a torque converter and manuals not....
  1. VR-VS engine convertion problems NEED HELP ASAP
    By SK8NVR in forum Electrical Wiring / Questions
    Last Post: 28-11-2010, 03:28 PM
  2. idle problems. won't sit at a constant idle.
    By macksvt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2009, 07:59 PM
  3. Problems with idle...
    By SAMO-87 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 28-08-2008, 04:16 PM
  4. Replies: 1
    Last Post: 06-10-2006, 06:22 PM
  5. Vs Ute Speaker install problems! plz help asap
    By damez in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 03-10-2006, 01:26 PM
