Results 1 to 3 of 3
Thread: vp v6 coolant flush plug locations
    92 VP Series 2
    Jan 2009
    East Brisbane
    Default vp v6 coolant flush plug locations
    hey so i have just done a coolant flush on my vp, but am pretty sure i missed a plug so i dont think i fully flushed it. i originally thought that the screws on each side of the engine (a few inches below the exhaust headers) were the correct screws/plugs but when i've taken them out today, no coolant came out. so i put them back in and started undoing random bolts that i could find and found one on the timing case cover (just below the water pump where the yellow circle is in the following picture), and a fair bit of coolant came out, but i was always under the impression there were 2 plugs you needed to undo to fully flush the coolant.
    can anyone explain to me or put a picture up where the second plug is?
    cheers for any responses
    Dec 2009
    you have undone a bolt that holds the water pump on by the looks of it, the thread on these needs to be sealed so you will have to use loctite on those when the thread in the block is dry otherwise the coolant will work it's way through the thread.
    Not sure about a Buick V6 but the Ecotech uses the knock sensors as the drain plugs, one each side, your motor only has 1 of these so I'm guessing there are some plugs up under the exhaust manifolds.
    FXST01's Avatar
    FXST01 is offline The Grey Man
    VP V6 Auto Sedan
    Jun 2005
    El-Arish-Shamal-Sina-Egypt
    There is one plug on each side of the block under where the exhaust mainfolds are, it is a small plug sitting in the middle of no where, it should be obvious once you start looking in that area. Or you could just undo the lower radiator hose.
    Illegitimi Non Carborundum
  1. Coolant flush
    By rob151515 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 14-01-2010, 12:07 PM
  2. Coolant flush on VS V6?
    By Raging Bull in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2007, 08:26 AM
  3. Coolant Flush
    By BOGANV8 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 06-06-2006, 08:59 PM
  4. Coolant Flush
    By desruction in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-06-2006, 05:31 PM
  5. coolant flush
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-01-2006, 01:20 PM
