Results 1 to 6 of 6
Thread: VS coil pack on VN?
    VN Series l
    Sep 2010
    Default VS coil pack on VN?
    Just wondering could you put a VS coil pack on a VN?
    S/C VN, VY SS, Waverunner GP1200
    Dec 2005
    S.A
    Yes you can. Bolt off, bolt on
    EDIT: Refer below
    UNDERCOVER HQ is offline HOT 202
    VN BERLINA 202
    Oct 2010
    townsville
    Default Coil pack
    They are diffrent you can ghange the tops. Two little screws either side of the coil will un do them. The hole bottom bit and bracket is diffrent.
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    I've just fitted a VR set of coils to the 88 wagon - just need to get the leads in the correct order.
    and 3 Dangerous non ABS VN's
    VR Series 2 Executive
    Dec 2007
    Shepp
    VS coil pack will not fit as the bottom bolts are different. VR coil packs will fit on thought. They have the VS style coils (3 groups of 2 plugs able to be removed separately ) but still have the same bolts as VN underneath.
    Dec 2005
    S.A
    I stand corrected. The VS coils and module will only fit if you have a mounting bracket from VN2-VR. VS coils screw into it's only bracket with the module sandwiched in between.
  1. [NSW] WTB VT VX VY coil pack
    By graham7773 in forum Swap / Wanted to Buy / Trade
    Last Post: 25-08-2010, 08:35 PM
  2. vs series 2 coil pack?? any coil pack will do????
    By steak000 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-12-2008, 07:52 PM
  3. Coil Pack
    By Willow01 in forum Electrical Wiring / Questions
    Last Post: 06-12-2008, 08:37 PM
  4. coil pack
    By ab56452001 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-01-2006, 03:16 PM
  5. Replacing Series I Coil Pack with Series II Coil Pack.
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-05-2005, 10:04 AM
