Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: VP V6 in-tank pump in VR SS BT1 Drop tank
    VKCOMMO's Avatar
    VKCOMMO is offline Carpark Mechanic.....
    Aug 2009
    Springwood, NSW
    Default VP V6 in-tank pump in VR SS BT1 Drop tank
    Hey
    Can i put my V6 fuel pump (stock tank) into a VR SS BT1 drop tank and make it work?
    Cause Ive been told that the V6 has one pump (high pressure) in tank and the V8 has a low pressure in tank and a high pressure inline
    Or can i just use the in-tank VRSSBT1 pump and it will work fine?
    Thanks
    VKC
    [09-01, 22:47] HoZy: VKC doesnt finger, He fists... Because Ranga
    Dec 2009
    If you have the bigger fuel tank your gonna need to take the fuel pump assembly out and see if it is a low pressure priming pump or a high pressure pump. the high pressure pump will look just like the one in your original tank and the primer pumps are a bit shorter plus I dont think there is a pulsator.
    You may be able to modify the bigger tanks pickup assembly to suit the high pressure pump out of your old tank instead of going to the trouble of fitting an external high pressure pump. If you can't figure out which pump is n it post some pictures of the pump and sender assembly from the larger tank.
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    informed me on CB that VP-VS had one high pressure pump, only VN had 2 pumps...
    I took a look today and noticed that a few lines are a bit different, So ill post them up. Or worst comes to worst grab a gregories
    mischa's Avatar
    mischa is offline <- 245rwkw Holden V8
    VN V6 T5 - 355 VN GRP A REP T56
    Jun 2005
    Ashbury, NSW
    Let us know jack, I wana ditch the 2 pump set up on my V8 and go the single.
    Quote Originally Posted by keza87 View Post
    Really who wouldn't want to give Jack a good smack in the back of the head.
    The Daily VN T5V6
    355 VN GRP A REP
    VS l67 statesman
    Dec 2008
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Quote Originally Posted by mischa View Post
    Will do.. Or you could come and do it, and learn then. LOL, Nah, ill take plenty of pics..
    Quote Originally Posted by vsl67 View Post
    When I swapped My petrol tank over in my V6 VP for A Vs SS 80liter tank I just changed over some electricle connections and it ran fine with the V8 pump
    Yeah, Im pretty sure VS have a different plug, VR are the same as VP..
    Ill have the pics up soon, Just got home from work so im fugged...
    EDIT:, OK, heres the pics...
    This is on my current tank in the car, and stupidly i forgot drop tank pics, so ill get those in the morning...
    See that pressed off there, the drop tank has another line there
    But instead, doesnt have this line:
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Pictures are blocked cause im at work but the return line on some cars goes into the internal fuel pump housing and some go into a welded on pipe up to the left and up a bit.
    Ill take a look at the pics when i get home at 7.30, dam 12hr shifts.
    The Daily VN T5V6
    355 VN GRP A REP
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Yeah, It looks like on the drop tank it goes to the fuel pump and on the VP it goes to a pipe welded off to the side a bit...
    vs commodore
    Oct 2009
    Tamworth NSW
    According to the VP gregorys manual,any VP built after 26th october 1992 has the fuel return line going back into the fuel tank through the fuel pump assembly instead of using a seperate return line back into the fuel tank, like the one in the pic above.
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Yep, your options here are.
    1. If the drop tank had a high presure pump in it (ie from a single pump set up) You can swap them stright over and run the return line to the pump housing and modify the connectors.
    2. If its a low pressure pump you can replace it with a high pressure one if you can or source a new pump assemble that can come from any tank thats got the return line on the pump. Plus side of that is you might be able to get one with the same electrical connector then!
    Im pretty sure the benifit of the return line on the pump is it gets returned directly into the swirl pot, not sure on the pipe mounted one if its got a line on he inside of the tank going to the swirl pot anyway.
    BTW, when do you get your P's?
    The Daily VN T5V6
    355 VN GRP A REP
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Quote Originally Posted by Brett_jjj View Post
    ahh.. Bugger, Mine is 27 august 1992
    Hmm, Not sure if its high or low, Airstrike seems to think it is high pressure...
    If i can get someone with those inspection camera's ill find out, But in all honesty, Unless i can, Ill just believe airstrike until i install it as i CBF removing the pump...
    Umm, booked my test for march the 18th... My birthday
    Black VN MANUAL
    Feb 2007
    Top of Vic
    I am getting a V8 Drop tank, but it doesnt have the Sender Unit in it, i was told a V6 one will fit because the hole on the V8 drop tank is lower or something, is this correct or do i need a V8 sender unit?
    ~ VN POWER ~ Click the scales
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Jack just remove the pump its not that hard, ive done it with a full tank of full, in the car, at eastern creek! The officals didnt seem to like me doing it tho.
    If I feel upto it sat arvo are you going to be home?
    The Daily VN T5V6
    355 VN GRP A REP
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Sorry, Just got home... Was at nats. I removed the pump about half way out and it was a bitch to put back, so thats my excuse.. LOL
  15. #15
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Mischa, You recon you could shed some light on it if I bring it around next time I go to yours? Maybe when I come down to do the auto lights...
  16. #16
    Haydz's Avatar
    Haydz is offline 346 cu/in
    VS UTE LS1 T56
    Nov 2007
    Liverpool.Sydney,NSW
    vr ss pump will be highlflow. they dont run twin pump setup.
    connect both the flow and return lines to the vr sender instead of the return onto the side of the tank. done
  17. #17
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Haydz, intanks are the same VN-VS regardless if there is a external or not.
    Yeah jack bring it round should be easy.
    The Daily VN T5V6
    355 VN GRP A REP
  18. #18
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
  19. #19
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Sweet Thanks Haydz and Mischa..
    Umm... Straps are IRS I believe. But Dan said he knows how to modify them to fit Live axle so im going to get him to tell me how to do it...
  20. #20
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    yeah i helped him do it. cut them in half so you use half of each and put a bolt through haah
  21. #21
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Bahahaha.. You serious?!?
    While im at CommWreck tomorrow ill take a look for an IRS strap... Am I right in saying only 1 strap is different?
  22. #22
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
    what you want is a live axle strap from something that had the 80 litre tank.
    which is usually luxury or v8
  23. #23
    Haydz's Avatar
    VS UTE LS1 T56
    Nov 2007
  24. #24
    VKCOMMO's Avatar
    Aug 2009
    Springwood, NSW
    Quote Originally Posted by Haydz View Post
    But which strap
    BTW why do you want an 80 litre tank
    Cause I have one lying around at home and I like the look of the drop tank
  25. #25
    mischa's Avatar
    Jun 2005
    Ashbury, NSW
    Haydz me or you would of done the same thing back in the day
    The Daily VN T5V6
    355 VN GRP A REP
  1. VR SS Drop Tank Into VP
    By VKCOMMO in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-12-2010, 01:19 PM
  2. Drop Tank.. Lowering Petrol Tank..
    By anton1o in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 25-05-2010, 05:52 AM
  3. VR Drop Tank
    By Oken in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-10-2008, 02:45 PM
  4. will a vn drop tank fit a vl?
    By Youngblood in forum VL Holden Commodore (1986 - 1988)
    Last Post: 24-09-2007, 12:20 AM
  5. vk drop tank
    By iosexy in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 06-04-2007, 05:35 PM
Tags for this Thread
