Hi, i have nearly finished touching up my car and all is looking good except for one pesky window trim on one of the rear doors.
It's that part jus below the window, grey with a black rubber bit.
How in the heck do i remove these ..... (I know i really need to buy a manual for it soon)
Anyone have any tips that would be greatly appreciated!
To remove the window gutter mould trim:
1) Wind down window
2) Start by lifting it up at the far end (end away from car body)
3) Use a little bit of force to remove, not to much or it WILL bend!
4) Try to pry to gutter mould off in short sections - not all in one go.
If it needs some help to get started, don't use a screwdriver, as it will damage the paint and may slip and destroy a lot more.
Use a strong bit of plastic, like a panel popper tool.
Also use to open window to help to remove the gutter mould makes it easier sometimes!
Good Luck!
- Stockies
