Results 1 to 7 of 7
Thread: weird feeling when cornering
    1990 VN exc
    Sep 2010
    bunaberg
    Question weird feeling when cornering
    i am testing ma car latly and when ever i floor it around corners the back end slides and feels loose( the diff or summin ) , dont know wats up have big sway bars and i am lowered but just feels weird
    HDTVL is offline RB30DET VL Calais
    VL Calais
    Dec 2010
    Palmerston North
    Have you checked your lower arms that are attached to the diff? a mate of mine had the same issue & it took ages to work it out & even though his seemed ok we replaced them with nolathane bushes & to this day he has not had a problem since
    1990 VN exc
    Sep 2010
    bunaberg
    lein's Avatar
    lein is offline Comrade Commodore
    VZ Ute
    Dec 2010
    Tropical QLD
    Panhard bushes will allow a little waggle from the diff too. But I agree with HDTVL have a squiz at your control arm bushes. IIRC you can buy complete control arms from places like REPCO with the Nolathane bushes already fitted for only a smidge more than the bushes. And the bushes can be a pain, I usually use the hydraulic press at work to change them.
    I aim to misbehave.
    vs commodore
    Oct 2009
    Tamworth NSW
    Thats the good thing about the nolothane bushes, they come in two seperate parts so you dont need to have them pressed in. The only ones I found that needed to be pressed in were the rear lower control arm bushes,these actually stay in the diff housing when the control arm is removed ,and need to be pressed from/into the diff housing..I just got front inner control arm bushes today, $45 for nolothane brand,I was expecting to have to press them in,but they are in 2 pieces with the crush tube, which is way easier to fit than the original rubber ones are.The pack came with 6 bushes and I thought, thats strange,and the guy at auto one where I got them didnt know why either.I got him to double check in the book that they were the right ones anyway,which they were..When I opened it and read the instructions,apparently the kit suits VR/VS or VT/VZ,and they all use the exact same front inner control arm bushes except for one piece which is different between the two styles of commodore,and you just select the right one for your model.I cant wait to get them in and get a wheel alignment done,get it back to how it was before..Its got nolothane all round now.With FE2 springs and these bushes,I find the ride and handling is excellent compared to how it was with standard height springs and rubber bushes..
    1990 VN exc
    Sep 2010
    bunaberg
    VL TURBO/ VS 5L STATO/ VP BT1 5L
    Jan 2010
    Im having the same problem, iv replaced the top control arms and panhard rod bushes, the only thing left is the bottom arms, so im guessing its that
    Quote Originally Posted by STEALTHY™ View Post
    Spmething like a VL mototr into a little carolla
  1. vr commodore, weird feeling through steering wheel and near pedals
    By jimbojones889 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-11-2010, 05:58 PM
  2. Assy starting and cornering
    By shanhsv in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-10-2006, 11:12 AM
  3. Noises While Cornering
    By Benji in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:44 PM
  4. Noise whilst cornering
    By toodles in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-04-2006, 08:27 PM
  5. Strange knocking sound when cornering hard
    By zeep in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 11-10-2005, 11:37 AM
